Question about Bosch 6" 60-120-240 Grit Sanding Discs for Wood (6 Pack) SR6R000
Circular saw Safety question
What kind of safety precautions should I talk before using this saw?
    President:
  • 2,712 Answers
Circular saws, like other power tools, can cause serious injuries if they are not used properly. Familiarize yourself with the owner's manual before attempting your first project. Make sure you are wearing safety glasses to protect your eyes from flying debris and ear protection to guard against hearing damage caused by the noise of the motor.
Posted on Aug 27, 2008
Where is the safety switch on a craftsman 10871 circular saw?
Fun Fact: The craftsman 10871 does not have a safety switch. That position is now occupied by the on off switch for the laser trac light. BE EXCEEDINGLY CAREFUL. A moment of complacency when you grab the saw with a finger in the trigger guard could easily filet your leg open or set it down with the blade guard open could relieve you of some unneeded digits.
Apr 10, 2014 | Craftsman Saws
The safety pin on my riobi chop saw is jammed -- when I push down on the handle and try to pull the pin out it's just stuck
you can try using a WD-40 to lube it or I am thinking that you are not getting enough travel to release the pin. Is the head of the saw hitting on something not allowing full movement. Let me know
Feb 25, 2012 | Saws
Any guard blade for a saw miter
Yes, Did you buy it new? It has two heavy plastic seen through plate that are attached to each other. This safety shield is gravity fed. That mean as one pull down the saw the safety guard will pivot into the upper shield. As the saw go back up after cutting a piece of wood. The safety shield will drop back into it safety position covering the 12" blade. GB...stewbsion
Aug 23, 2011 | Bosch 12" Dual - Bevel Compound Miter Saw...
Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
Jun 14, 2011 | Porter Cable Plywood Circular Saw Blade
Can not unlock saw
there is a safety button[usually by thumb area when u grab handle ] on most saws that has to be pressed as well as the switch when using circular saws
Jan 18, 2010 | Saws
Ryobi 10'' Miter saw Model 251U
http://www.ereplacementparts.com/ryobi-csb141lzk-714-double-insulated-laser-circular-saw-parts-c-7931_7969_7981.html?keywords_category=CSB141LZK
Nov 24, 2008 | Ryobi 12A 7-1/4 in. Circular Saw
Circular saw Safety issues
If you are left-handed, you must be extremely cautious when operating a circular saw, since most saws are designed for right-handed operation. But if you can, you'll be better off with a left-handed model or an adjustable one (suitable for right-handed and left-handed as well).
Aug 27, 2008 | Bosch 5" 60-grit Sanding Discs for Wood (5...
Bosch 6" 60-120-240 Grit Sanding Discs for Wood (6 Pack) SR6R000 Logo
136 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
