Question about Astro Pneumatic AP 1718 Deluxe Air Blow Gun with 4" Long Angled Nozzle & 1
Blow Gun Specs
What are the specifications for air blow guns?
    President:
  • 2,712 Answers
Specifications for air blow guns include pressure capacity and air line connection type. Pressure capacity or maximum rated pressure is rated at the air inlet and measured in pounds per square inch (psi). Many types of air line connectors are available. Quick-release connectors contain fittings that are attached internally. By contrast, push-on connectors include barbed ferrules. Air blow guns use several types of national pipe thread (NPT) connectors, most of which are inch-based and female. Important NPT measurements include threads per inch (TPI) and outside diameter (OD). 1/8” NPT connectors have 27 TPI and an OD of 0.405”. 1/4” NPT connectors have 18 TPI and an OD of 0.540”. 3/8” NPT connectors also have 18 TPI, but an OD of 0.675”. 1/2” connectors have 14 TPI and an OD of 0.840”. #10-32 NPT threads are also available. Air line connections that can swivel or pivot are suitable for applications that require versatile positioning.
Posted on Aug 27, 2008
When my Senco SLP 20 brad nailer is connected to air hose, air will blow-by through the exhaust. After you fire a couple of pins blow-by stops
Most problems with this gun centers around the firing valve part # Bao119 . This part must not get any oil because it will swell and begin to fail as you describe. That being said, the trigger valve does need some type of lubrication or it will become sticky causing problem that you describe. If you have been using oil in the gun, most likely inner trigger parts will be lubricated and failure is firing valve. If no oil has ever enter the gun, suspect the trigger valve. It will need to be removed from the gun and lubed with white grease or silicone lube. Good luck
Dec 05, 2014 | Air Tools & Compressors
SOLVENT TO UNPLUG CLOGGED AC EVAPORATOR DRAIN IN CAR?
Best way is to take it to a shop and have them take the air hose with a blow gun attached. Put the blow gun in the drain hose and squeeze the trigger a couple times real quick should take care of any clogs
Jun 11, 2014 | 1995 Buick Riviera
Air blowing out the back of nail gun
That is just the blow off (extra air) coming from the air compressor that your nail gun didn't use.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 07, 2011 | Office Equipment & Supplies
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
Nail gun will not shoot and air is exhausting out top vent all the time.
Oct 21, 2010 | Garden
The gun will not hold air
water in the compressor causes this....drain compressor after every use...you can buy a dryer at lowes.....you can also buy new gaskets at lowes....
Nov 16, 2009 | Air Tools & Compressors
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
Most of the car radio buttons don't work.
You want to purchase a small can of Compressed air,local computer store,Rshack,and this will allow you to apply compressed air to the surface of the radio in hopes to dislog that which my be causing a malfunction .
Please rate. Thanks jj505
Mar 20, 2009 | Mintcraft CC970 Air Blow Gun 13"
How to use to clean my car?
Shoot the blow gun in all the tight spaces where your vacuum hose can't reach. If possible, attach a small jet pipe on the end of the gun to reach the tiniest crevices.
Aug 27, 2008 | Legacy Rubber Tipped Blow Gun
Astro Pneumatic AP 1718 Deluxe Air Blow Gun with 4" Long Angled Nozzle & 1 Logo
263 people viewed this question
Top Astro Pneumatic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Astro Pneumatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
