Question about Black & Decker WP900 6 Inch Random Orbit Waxer/Polisher
Tile Saws for shor and vurved cuts
What kind of tile saw should I use for short and curved cuts?
    President:
  • 2,712 Answers
A 100mm angle grinder is used for that kind of work. It can also be used for "L" shaped cuts and for making holes. It is usually being used dry and more rarely used wet
Posted on Aug 27, 2008
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Jun 07, 2010 | Imer Tile Saw Combi 200va Portable Tile...
While using the rz10 tile cutting wheel the saw has no tourque any kind of resistence the wheel stops
The only tile that they are any decent at cutting would be ceramic, slate, or terracotta. Anything else is way too hard and even cutting the listed tile it's no joy to do. I would suggest using a 4 or 4 1/2" grinder with a diamond blade coupled with a wetsaw. hope this helps and good luck.
Mike
Jan 02, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
I need to buy a tile saw I was searching on the internet & after spending 3 hours I came across this impressive website http://www.ciciliotandson.com/. I just want to ask you that are they reliable ?
Hi, I just went to that site you posted, I don't know what saw you were looking to buy, the saws looked like good quality, BUT they all looked very overpriced. Ive been doing tile since 1984 and have owned, mk,target, felker, pearl, tile saws. everyone of these saws have a 10 inch blade and are very very good for a thousand dollars you can get these saws with saw stand,blade all the gauges ready to cut.the pearl saw \pearl abrasive co.\vx 10.2xl has a 1 1\2 hp motorweights 83 pounds and cut a 2 foot by 2 foot tile or a 18x18 diagonally,great saw,the mk, target and felker have saws that will cut the same size of tile but are bulky in size.if i was you go ask tile setters at a tile store, before you buy a saw.good luck Chad
Jun 11, 2009 | Saws
Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Aug 31, 2008 | Saws
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Tile saw stopped working
check the motor might have a reset botton or check the capacitor
May 31, 2008 | Dewalt DW746X 10" woodworker's table saw...
Black & Decker WP900 6 Inch Random Orbit Waxer/Polisher Logo
301 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
