Question about Dewalt DW746X 10" woodworker's table saw with rai
Circular saw costs
How much does a circular saw usually costs?
    President:
  • 2,712 Answers
The more compact design, in which the motor sits alongside the blade — starts at around $100. There are many saws on the market under this price, but they're not as powerful, nor are they built for a lifetime's use. Professional-grade sidewinders, which run quieter and cut through dense wood better, cost between $125 and $150.
Posted on Aug 27, 2008
My Ryobi scroll saw made a pop sound when I was using it. Now it won't go. How do I fix this?
pop as in electrical pop? if so it sounds like a brush problem at the commutator. If it is worth fixing cost wise electric power tools can usually have brushes repaired if you know how.
Jan 24, 2015 | Ryobi Saws
How to dismantle Motor housing for a makita cordless circular saw for diagnoses
The replacement part will cost about as much as a new saw. The housing and case is probably warped and deformed enough that it would nearly impossible to get the old one out and a new one in.. Get a new saw.
Aug 19, 2014 | Saws
What size brushes does the Apprentice 7-14 10 amp circular saw use
www.ereplacements.com they will ask for your model number and the name of the saw. Cost should be somewhere around $20.00 for
new brushes.
Jul 12, 2014 | Apprentice 7-1 4 In 10 Amp Circular Saw...
Dewalt circular saw runs like power lacking intermit ant
The armature is bad. A new armature is about the same cost as a new saw. Buy a Milwaukee next time.
Mar 14, 2014 | Dewalt Saws
Mastercraft miter saw parts
I have no idea but where did you originally buy the saw? Seller might be able to help you with that. What do you usually cut in your saw? I got circular blades from sawblade.com , check them out.
Jan 05, 2014 | Saws
Circular saw won't start after having cut pavers
You fried the motor and most of the time it isn't worth repairing, since the parts will cost you more that a replacement saw.
If you are going to continue to cut pavers, suggest you either take it very slow and cut 1 or .5 paver and then let it cool down. But a water cooled tile saw would be better.
Jun 24, 2011 | Saws
I cannot loosen the bolt that holds the blade on my 7 1/4 Makita circular saw. How do I make the blade stop spinning to loosen it?
they make a blade holder now but usually if you hold the blade against a wood block real tight you can loosen the bold / screw . most warn against over tightening them
Sep 04, 2010 | Makita 18V LXT Circular Saw
I sawed the power cord in half...! It was a skil saw brand But obviously I am 'unskilled'... The saw cost about $65. Can this be repaired or should I get a new saw...?
Yes it can be repaird. No offense, but can you do it? Take handle appart, may have torx screws, and remove old cord. You can buy a new exact replacement cord or a generic cordset to replace. Check wire size on your old cord.
Jul 25, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Sep 28, 2009 | Ryobi P501 18v Circular Saw Only
Dewalt DW746X 10" woodworker's table saw with rai Logo
123 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
