Question about Dewalt DW8308 60-Grit. 4 1/2" Blue Zirconia 7/8" Arbor Resin Fiber Discs
How to use Tile Saw
How do I use the tile saw?
    President:
  • 2,712 Answers
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Posted on Aug 27, 2008
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Jun 07, 2010 | Imer Tile Saw Combi 200va Portable Tile...
Husky wet tile saw repair service
I need to order a part for my Husky wet tile saw. can someone give me an email address. web serches are a bust.
Aug 24, 2009 | Husky Wet Tile/Stone Saw with with Laser...
How to fix a tile saw pump
take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Jul 14, 2009 | RTO 6391K Felker 24" Tile Master Plus Wet...
I need to buy a tile saw I was searching on the internet & after spending 3 hours I came across this impressive website http://www.ciciliotandson.com/. I just want to ask you that are they reliable ?
Hi, I just went to that site you posted, I don't know what saw you were looking to buy, the saws looked like good quality, BUT they all looked very overpriced. Ive been doing tile since 1984 and have owned, mk,target, felker, pearl, tile saws. everyone of these saws have a 10 inch blade and are very very good for a thousand dollars you can get these saws with saw stand,blade all the gauges ready to cut.the pearl saw \pearl abrasive co.\vx 10.2xl has a 1 1\2 hp motorweights 83 pounds and cut a 2 foot by 2 foot tile or a 18x18 diagonally,great saw,the mk, target and felker have saws that will cut the same size of tile but are bulky in size.if i was you go ask tile setters at a tile store, before you buy a saw.good luck Chad
Jun 11, 2009 | Saws
Bushings for tile sew
I do not know what brand of tile saw, but wwww.toolsandmachinery.com sells part for tile saws.
Sep 06, 2008 | Saws
Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
Aug 27, 2008 | Mk Diamond MK 101Pro Tile Saw
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Dewalt DW8308 60-Grit. 4 1/2" Blue Zirconia 7/8" Arbor Resin Fiber Discs Logo
841 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
