Question about Dewalt DW8306 36-Grit. 4-1/2" Blue Zirconia 7/8" Arbor Resin Fiber Disc
Tile Saws question
Why can't I use regular saws for tiles? Like an ordinary circular saw for wood or metal?
    President:
  • 2,712 Answers
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Posted on Aug 27, 2008
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Where do I buy parts
i beleave target makes husqvarna try that 1st,if not try a tile store that sales saws,1st,try target tile saws i bet they will take care of you
Feb 25, 2011 | Husqvarna Tile Saw Tilematic Ts 250 X3...
Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
Jan 24, 2010 | Saws
Need Parts breakdown for this model on a Target brand Quickie Saw Model 12-65
fyi, target tile saws and felker tile saws are made by the same company, and you can find both of them on line. your best bet is to take your saw to a tile distributor that sells saws and they will get what you need , good luck
Jun 27, 2009 | Target Saws
I need to buy a tile saw I was searching on the internet & after spending 3 hours I came across this impressive website http://www.ciciliotandson.com/. I just want to ask you that are they reliable ?
Hi, I just went to that site you posted, I don't know what saw you were looking to buy, the saws looked like good quality, BUT they all looked very overpriced. Ive been doing tile since 1984 and have owned, mk,target, felker, pearl, tile saws. everyone of these saws have a 10 inch blade and are very very good for a thousand dollars you can get these saws with saw stand,blade all the gauges ready to cut.the pearl saw \pearl abrasive co.\vx 10.2xl has a 1 1\2 hp motorweights 83 pounds and cut a 2 foot by 2 foot tile or a 18x18 diagonally,great saw,the mk, target and felker have saws that will cut the same size of tile but are bulky in size.if i was you go ask tile setters at a tile store, before you buy a saw.good luck Chad
Jun 11, 2009 | Saws
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Tile saw stopped working
check the motor might have a reset botton or check the capacitor
May 31, 2008 | Dewalt DW746X 10" woodworker's table saw...
Dewalt DW8306 36-Grit. 4-1/2" Blue Zirconia 7/8" Arbor Resin Fiber Disc Logo
299 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
