Question about Black & Decker 5/8 Hp, 6" 150MM, Heavy Duty Bench Grinder, Powerful"
Precision work question
Does bench grinders designed for precision work
    President:
  • 2,712 Answers
Bench grinders aren't designed for precision work. In fact, they're really freehand tools that rely on a good eye and careful touch. And while you can take some tools, like drill bits or turning tools, right from the grinding wheel to the work, it's common for grinding to be a relatively coarse, preliminary shaping procedure, followed by careful honing on a whetstone.
Posted on Aug 27, 2008
How do I operate bench grinder?
A murphy, A bench grinder must be used with a lot of caution and respect while using this equipment, Check the attached links,instruction and guides, Good luck work safe.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OSH Answers Fact Sheets
Pedestal Bench Grinder Safety
Bench Grinder Basics
Mar 21, 2016 | Bench Grinders
My ryobie bench grinder keeps tripping the rcd within a second of turning it on?
Assuming your local tech confirms that your bench grinder tests ok. The problem is probably that the grinder draws too much current for the RCD and is therefore detected as an earth leakage. High amperage devices often do that. Your best bet would be to plug it in to a socket which is on a non-rcd circuit. Maybe you have an RCD on the whole house though? I would start with returning the grinder and trying a different brand with a lower amperage/wattage rating. If that doesnt work, I would call an electrician to discuss installing a different RCD or running a separate circuit for your power tools.
Mar 03, 2011 | Jet Industrial Bench Grinder 6in new
Cant get a on off switch anywhere co that maid it for wilton is out of business what a scam.
Repair parts have always been a problem.
See if you can get into the electrical area ... open the bench grinder from underneath ... tie the switch wires together ... put a regular wall switch on the electric line.
I hope it works for you.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
Need an on/off switch for a buffalo bench grinder model B-6CB 1/2 hp. 41/2 amp. serial #775713
I had the same problem with a Northern Tools bench grinder. These are made in China and parts are hard to come by. I had enough room after removing the old broken on/off switch to install a single pole 15 amp light switch like you use in your home. I simply installed it horizontally and then put the switch cover on. It works perfectly. If you do not have enough room then look for any 15 amp or larger switch that will fit in the housing. Any on/off switch will work. You could even mount the switch on the bench in a switch housing and run the wires from the grinder to the switch and back if need be. Just be safe and make sure there are no exposed wires. As a last resort you could remove the switch connect the wires, eliminating the switch and use a plug in wall switch such as this. 4147a14.png
Apr 23, 2010 | BUFFALO 10" Bench Grinder
Bench Grinder blown fuse
try the fuse first then try the red reset button under the base.
Mar 05, 2010 | Clarke Power Products Cast Iron Bench...
I need an owners manual for delta gr450 8
Here's a link to download the pdf.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A15786.pdf
If it doesn't work, start here:
http://www.deltaportercable.com
Mar 02, 2010 | Delta Shopmaster 8" Bench Grinder
Grinder wheel wobbling
check bearing for play and or race for wear on wheel
Oct 06, 2009 | Grinders
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Aug 27, 2008 | Clarke Power Products Cast Iron Bench...
Grinder Types
Bench grinders are perfect for sharpening cutters, bits, blades and hand tools. Any piece that needs smoothing, shaping, or polishing can be done at the bench grinder. Straight grinders or angle grinders are portable, handheld tools with wheels that range from 4 to 9 inches. They are the best grinders for working on pieces that may be too large to fit at a bench.
Aug 27, 2008 | kawasaki 7" or 9" Angle Grinder
Black & Decker 5/8 Hp, 6" 150MM, Heavy Duty Bench Grinder, Powerful" Logo
221 people viewed this question
Top Black & Decker Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Black & Decker Grinder Expert? Answer questions, earn points and help others
