Brother P-Touch 1180 Label Printer Logo
Posted on Jul 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Label maker is printing blank labels when text has been typed in. Need fixed as soon as possible.
Saleem Baig
Level 2:
  • Expert 283 Answers
  • Posted on Jul 14, 2011
Saleem Baig
Expert
Level 2:
Answers
283
Questions
0
Helped
62485
Points
806
1st of all did you check and made sure the cartridge is working fine?
If not try to take the cartridge our of the printer and inspect if the tape is cut, if found to be cut replace it imdly. Take help of the user manual for replacement of the cartridge etc.,
Dymo LabelWriter 330 is cutting off part of my address labels
You should have the text box to type in. You can click on the dotted line and move the whole box up or down so the entire text will be mostly centered on the label.
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
What is a label maker used for?
Label makers are used to develop the text design to print on labels.
For eg, in retail industries, they make labels(stickers) for printing Price tags along with item description and barcodes.
Label makers is a software which enables the user to frame their text position, fonts, description etc..! with which they their desired design in labels via a label printer.
hope we made u clear.
if you need info on label makers.
please see our site www.trridevlabelss.com
I want to print a label with two lines of print on it. How do I do it?
To create a two-line label 1. Type the text for the first line and press INSERT. 2. Use the arrow keys to select Second Line and press . A multiline symbol is inserted at the end of the first line, but will not print on the label. 3. Type the text for the second line.
Here's the manual, see page 12 - http://www.dymo-label-printers.co.uk/downloads/LetraTAG-LT100H-Manual.pdf
I want to print a label onto a DVD I am burning using my HP6180 All-in-one printer. Does anyone know how i can do it?
Your printer is not printing straight to a DVD, so you will have to buy self adhesive labels, print on them and then stick the label on the disc. Now, it all depends on what software you have available. Your might have software included with the Photosmart printer for CD/DVD label printing, check your installer CD that came with the printer. If you don't, and use Nero for burning DVDs, you may notice it has a label printing software that comes with it. You will need this type of software in order to print a label. If you don't have Nero, or any other label printing software you can try using some of the free ones that are out there, like Disketch 2.11. There's also a lot of free to try label printing software, like Acoustica CD DVD Label Maker which you can use for 15 days for free. If you have Photoshop and you're good using it, then this is another option to consider (you can download templates online).
Using a label printing software is pretty easy, most of them will have templates that you can open and just edit, or you can start with a blank design and add text and pictures to it. When you are finnished put the special label paper in the printer and click print. If you have special DVD labels make sure you specify that in the printing preferences before you print.
2answers
3helpful
2answers
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
1helpful
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Norman Weimar
Norman Weimar
k24674
