Question about Milwaukee Tool Milwaukee 6230 Deep Cut Portable Band Saw
Blade width usage
What blade width to use?
  • David Ford
    David Ford May 11, 2010
    has your problem been solved? I am aware of only one blade fitting this tool and that is the standard blade but you have your choice of TPI
    President:
  • 2,712 Answers
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Posted on Aug 27, 2008
REXON BS 10 .3 WHEEL BANDSAW 20 YEAR OLD , WHAT IS MAX BLADE WIDTH I CAN USE . THANKS
open it and measure the drive wheel width . only a guess but 1/2 in might be all
Feb 02, 2017 | Blade Saws
Adjust stitch width to narrow for an Elna 654 overlocker
What you are looking for is "cutting" width. The adjustment moves the cutting blades in or out, thus increasing or decreasing the seam width.
Mar 11, 2016 | Elna Sewing Machines
BANDSAW BLADES
AWSBS2 band saw takes 70 1/2" long blades. Blade Widths : 1/4", 3/8", 1/2" .
Apr 14, 2014 | Saws
Meat slicer: when slicing our pork loin the meat will stick up under the blade at the bottom causing the meat to spin off the slicer?
The blade may require cleaning in between usage as the oils and sugars are solidifying on the blade from previous usage causing the meats to adhere to the blade when sliced.
Dec 22, 2013 | Kitchen Appliances - Others
The check engine light came on message was in reference to the TAC?
Hi there:
DTC P0638 - Throttle actuator control range/performance
The engine control module (ECM) opens the throttle blades by applying a pulse width modulated voltage to the throttle valve motor. The ECM reverses the polarity on the throttle valve motor control circuits in order to close the throttle blades. The ECM increases the pulse width as necessary to open the throttle blades. The ECM monitors the throttle position (TP) sensors 1 and 2 to determine the actual blade position. If the ECM detects the required pulse width modulation (PWM) to move the throttle blade exceeds a predetermined value, DTC P0638 sets.
According with recalls...
REPAIR ACTION:
* Replace the Throttle Position Sensor (TPS)
* Perform the ECM software update.
NOTE :Always perform a GDS ECM Update by Automatic Mode first as it performs error checking to ensure the correct data is flashed into the vehicle. Always select the latest available ECM Update event data at time of your update.
Feb 28, 2012 | Volvo S60 Cars & Trucks
Check engine light is on something about the TAC?
Hi there:
REPAIR ACTION:
Feb 28, 2012 | 2007 Volvo S60 2.5T
Poulan pro, right out ofr the box model pr625n21rh3 serial 012010m 004039. the problem is it won't cut the full width of the deck , have to overlap 3" to get full width cut????
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Jul 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Grinder support
They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
Aug 27, 2008 | Speed CGW ABRASIVES 35606 "24 GRIT" HIGH...
Milwaukee Tool Milwaukee 6230 Deep Cut Portable Band Saw Logo
252 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
