Question about Ridgid 14" Band Saw with Stand
Motor power question
How does the horsepower effect the work?
    President:
  • 2,712 Answers
Horsepower is the maximum power produced by the motor. Saws with high horsepower ratings are good for pattern cutting and cutting down thick stock. Higher horsepower also allows the saw to cut through thick stock without bogging down or burning the wood.
Posted on Aug 27, 2008
What does Brake-horsepower do in a truck and what effect it has on braking on trucks?
Nothing and has no effect on braking. It is a measurement of power at a certain RPM.
Oct 28, 2017 | Cars & Trucks
What is the motor hp?
Please see below courtesy of engineeringtoolbox.com
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
where
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
where
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
Feb 03, 2016 | Boating
Will an electric motor with more horsepower and more rpm hurt a compressor pump?
Electric motors seem to turn around 1125 rpm or 3600 rpm. The pulley size on the motor and pump must be adjusted to achieve the desired result without overheating /loading the motor. I have seen pumps turning from 800 to 1200 rpm using different pulley size on motor, motor hp and motor rpm. Some brands will turn same pump from 1200 to 3600 rpm depending on if was electric or gas motor. This will certainly shorten the life of the pump but will most likely work. Most turn an average of 1200 rpm for good balance of long life and good supply of air. Pump rpm is usually limited to the power of the motor. Cost effective match of 1.5 hp motor will turn pump about 1000 - 1200 rpm for about 5cfm. Rol Air 2hp motor turns 2 cyl pump about 1100 rpm for 10 cfm. Good luck
Mar 17, 2015 | Campbell Hausfeld Tank Air Compressor, 1...
I ran a diagnotic and my car doesnt have horsepower
Yes, but it would depends on what type of engine you have and it would not be street legal is you did add that much horsepower.-----------------------------------------------------------------
Godiag T300+
Nov 27, 2012 | 1998 Jeep Grand Cherokee
Wat can I do to get better gas milage in my 1989 chevrolet Corvette without droping horsepower or torque?
Make sure the engine is properly tuned. Check tire inflation. Accelerate slowly. Anticipate stops. Probably not what you wanted to hear when your driving a Corvette but there are no magic solutions.
Jun 21, 2011 | 1989 Chevrolet Corvette
I want to but a 3 HP Baldor 220 motor on my 10" craftsman table saw. Will the motor mount be able to stand the stress of a heavier motor without pulling the arbor out of square with the table?
A 1/2-horsepower motor wired for 220 volt operation is ample for this hand-fed saw. Using a much larger motor will lead to some serious kick-back problems because the motor will continue to turn if the cut becomes bound. A higher horsepower motor requires power feed for the stock to control kick-back. Hope this helps!
Dec 30, 2010 | Garden
Does the Nordi Track Commercial zs Treadmill have a 3.0 CHP
It is continuous. Some manufacturers used to say just "horsepower," when "continuous" horsepower was really a better measure. Consumers picked up on this and started asking your question. Now the horsepower quoted by almost all brands, including NordicTrack, os continuous. However, they got lots of consumers asking "What does 'continuous' mean? so now they just say "horsepower," even though it is "continuous" horsepower! For a full explanation of what this means, see treadmill answers.
May 08, 2010 | Nordic Track NordicTrack Treadmill, A2550
Tillers what type of motor?
* Engine Options -- Tillers come in four- and two-stroke models. o Get a four-stroke engine if you can. + Easier to start up than two-stroke models. + Require less maintenance and are more convenient because they don't require any mixing of fuel and oil. + Produce less exhaust. o The more horsepower, the more powerful your tiller will be. + Rear-tine tillers generally have more horsepower than any other kind. + You'll appreciate that horsepower when you have hard soil to till.
Aug 27, 2008 | Mantis Border Edger Attachment
Air Compressor question
No, When an air compressor is built, it requires a motor or engine to power the process of producing air. The horsepower is not the only component of the equation. It has to be combined with the compressor pump that it runs to produce the air needed. The bigger the horsepower does not necessarily mean more air. Remember to keep your required cfm in mind. Horsepower does not make you work more efficiently, but horsepower working in unison with a quality pump that produces enough cfm for your needs. Make sure when shopping that you look for the running horsepower and not the peak horsepower you get at startup. Some manufacturers have falsely advertised or implied the peak horsepower to be the normal run horsepower. At start-up, there is a surge of power needed to start the motor and can be 1.5-3 times the amount of running power needed. This means the horsepower need for the motor peaks as well, but then drops back down to normal. Many of these manufacturers are involved in a class-action lawsuit for misrepresentation. They have used man’s machismo of “the more horsepower, the better” to their advantage to make sales. These aren’t cars we’re talking about!
Aug 27, 2008 | Porter Cable 4 5 Gallons 150PSI Job Boss...
How Does horsepower effect usage?
Horsepower measures the power of the router's motor. Routers with more horsepower can perform more heavy-duty cutting.
Aug 27, 2008 | Bosch 1617EVS Router
Ridgid 14" Band Saw with Stand Logo
122 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
