Question about Jet 708718R Rip Fence with Resaw Guide
Model variations what are the model variations availbale?
    President:
  • 2,712 Answers
Bench-Top saws can be mounted directly on a workbench or on their own stands. Their compact size makes it the perfect choice for small shops and light scroll cutting. Floor-Model saws are usually more stable and more powerful than bench top saws. The combination of increased stability and power make these saws excellent for heavy rip sawing and decorative work on thick stock.
Posted on Aug 27, 2008
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
Tip
Lost your SKY router password and username then help is HERE
Read and accept the discalimer carefully this does work 100% of the time make sure that you select the correct model the black router will v1.9 firmware is the Sagem F@ST 2504 model the others older models are Netgear DG model variations.
https://www.cm9.net/skypass/
Happy finding
on Feb 28, 2010 | NetGear DG834G Router
Lifters pontiac replacement cost
Can't say. Big variation in the cost of lifters depending on whether pattern or OE parts and a big variation in fitting time depending on engine design, accessibility.
Someone will probably take a guess if you repost with model and year of car.
Jun 26, 2016 | Pontiac Cars & Trucks
Looking for agitator parts for 909278 maytag style Master
There appears to be variations of this model. Here is a link to one company who may have the parts and assistance you are seeking:
Here are the model number variations:
  1. MFW9700SB0 - Washer
  2. MFW9700SB1 - Washer
  3. MFW9700SQ0 - Washer
  4. MFW9700SQ1 - Washer
http://www.appliancepartspros.com/search.aspx?model=mfw9700s
Jul 21, 2015 | Maytag EPIC MFW9700S Front Load Washer
I keep getting ea server not availbale when trying to get on tiger woods
ea took down some of there servers for some games like tiger woods
Sep 29, 2014 | Microsoft Xbox 360 Console
I have a voltas vertis AC a model which only has on/off switch on the panel. There is no button to control temperature or anything on the panel. I have lost my remote and unable to get it from market. Is...
You can't adjust without remote. Please tell your A/c model number i will advise you where the remote is availbale. And also any of voltas dealer can help you to get it.
May 02, 2014 | Heating & Cooling
Can't get speed up above 35 mph
- this problem might be a worn variator-belt/rollers - the Vespa technology requires a variator-belt service every 10'000miles
- contrary to the belief that the carburetor causes such trouble it is a common issue with Vespa engines that people are not doing the replacement of the variator belt in due time...
Apr 27, 2014 | 2008 Vespa LX 150
Windows 8 has virus
You will need to a good virus protection scheme on the system. The two I suggest are Malwarebytes and/or Stopzilla AV.
http://www.skillbank.co.uk/free_software.htm
http://www.skillbank.co.uk/free is availbale at no cost.
Apr 15, 2014 | Computers & Internet
Setting the variator gilera dna 50
Hmmmm.
I'll look at dates first, next time.
This might have helped, two years ago!
http://www.scootershack.co.uk/threads/scooter-rollers-how-they-work-and-how-to-set-them-up.11966/
At least I learned what a variation is!
all the best.
Jul 15, 2012 | 2005 Gilera DNA 50
How do i delete inbox messages all at once on my nokia c6
airman33r ,
once you are in inbox, please try below:
1. click options>mark all (there maybe some variations on different model/versions) 2. click options>delete all marked (there maybe some variations on different model/versions)
hope this helps...
Aug 22, 2011 | Nokia C6 Smartphone
Jet 708718R Rip Fence with Resaw Guide Logo
108 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
