Question about Mountain 7" Angle Air Polisher
Polisher Usage what is the right way to work with the polisher?
    President:
  • 2,712 Answers
You must keep your polisher moving to avoid building up a concentration of heat in one spot. Try to keep the pad completely flush with the paint – this will distribute the friction throughout a larger area, dispersing the heat evenly throughout
Posted on Aug 27, 2008
What replacement battery can I get for my simoniz 18vbuf cordless polisher
You can either contact the people that made it and pay an outrageous price, or you can go to a place like batteries plus and buy a replacement that is what I call a re-pop for about half the price of the maker. You'll find a link to them attached
Jun 02, 2014 | Simoniz 18VBUF CORDLESS POLISHER CORDLESS...
Wiring diagram electric hob
www.electroluxappliances.com/Owner-Support
Aug 14, 2013 | Electrolux E604-220V50HZ Model E604 Floor...
Makita 9227c polisher started clicking and i smell smoke
sounds like you have a problem with the armature. To easily check UNPLUG tool and turn the spindle by hand and listen for the clicking. It sounds like it may be a raised commutator bar. You can also remove the brushes and look into the brush tube with a flashlight and look for a major discoloration of the bars or one that is raised.
Dec 18, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
Hi can I use my Dewalt polisher and change to sandpapper if so what parts will i need for instance glue new flexable pad sticky 220 papper can you please elaberate a little what in going to need thanx ...
I'm not sure I understand your question, but I'll give it a go.
The DW421 is a sander already. If you want to change it to a polisher, you can buy polishing pads to go on it.
If you have a Dewalt polisher and want to convert to a sander, you can buy sanding disks to fit your polisher. They are installed on the spindle and I believe you can get a backing pad for it also.
Hope that helps
Mar 19, 2011 | Dewalt DW421 5'' orbital sander
I need a set of brushes for the sander polisher.
try going to Makitatools.com and buying them direct from their site or find there service center locator for authorized repairs and buying them that way. Let me know if you need more help and if you do please furnish me with the zip code if you have one and the exact location and I will try and find someone local if I can.
Nov 23, 2009 | Makita Tools 7" Electronic Sander/Polisher...
My dewalt polisher will doesnt turn on when connected to outlet?
I would check the brushes. These are small carbon blocks that transfer the electricity to the armature and are usually easily accessible from outside the tool. Look for two round disk like caps with a screw slot. Undo the caps and take out the brush and you may find it is worn to the limit.
Sep 03, 2009 | Dewalt Dw849 Electric Auto...
How do I disassemble a dremel shoe polisher? thanks
take the 4 screws out of the bottom and take the plate off. then take the 2 screws out of the the actual polisher unit. also take the 2 screws out of the button connector thing. after that remove the electrical caps to all the wires and untwist the wires and take off the polisher unit. heres the hard part. get strong pliers or a strong gripping tool and grab hold of the metal securing covering the motor. rip the metal were it comes around and meets and once you have done that (it will take a while), the whole metal covering will come off. next you have to take the polisher pads off and untwist the plastic cones underneath the pads. now you need needle nose pliers and you will have to untwist the 4 nuts on each side with the pliers. once you have done that you can take the nuts off and slide the black motor coverings and you are left with the motor and you have disassembled the Dremel Shoe Polisher.
Aug 27, 2009 | Dremel Tools & Hardware - Others
Typical speed question
It spins typically from 600-3000 RPMs. This single motion allows a circular polisher to level the clear coat that surrounds a scratch so that the scratch’s “edges” disappear. Professionals who want to completely remove a deep scratch must use a circular polisher.
Aug 27, 2008 | Taylor Pneumatic: Angle Polisher:. 2500...
Mountain 7" Angle Air Polisher Logo
372 people viewed this question
Top Mountain Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Mountain Tool and Hardware - Other Expert? Answer questions, earn points and help others
