Question about Taylor Pneumatic: Angle Polisher:. 2500 Rpm. Air Pressure: 90 Psi. Air Inlet: 1/4" Npt
Typical speed question
What is the typical speed?
    President:
  • 2,712 Answers
It spins typically from 600-3000 RPMs. This single motion allows a circular polisher to level the clear coat that surrounds a scratch so that the scratch’s “edges” disappear. Professionals who want to completely remove a deep scratch must use a circular polisher.
Posted on Aug 27, 2008
How to use star speed cycle on thermador dishwasher
A typical insruction in Thermador dishwasher manual explaining use of the star speed program...
Apr 19, 2014 | Thermador Dishwashers
What is the typical warm up time for a 2002 XL1200C Sportster?
Hi David, I usually let my bike idle 2-3 minutes with the choke on then take off, once I get up to speed, push the choke in depending on outside temperature. Good luck and have a nice day.
Aug 09, 2012 | Motorcycles
Blower moter will run only on high
The most common cause is a bad blower motor resistor. It attaches to the blower motor and controls fan speeds. It's typical for a bad resistor to lose 1 speed at a time until you are left with just 1 speed as you are experiencing.
Oct 30, 2011 | Cars & Trucks
I REPLACE SWITCH 77075 now IT HAS ONE SPEED IDID ONE WIRE AT TIME WHAT IS THE PROBLEM
I don't know your specific fan or switch.
Following link is TYPICAL illustration of 3-wire fan switch wiring:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
Three way switch is designed to match TYPICAL fan motor windings.
Motor windings are insulated copper wire wrapped around metal fan housing, similar to electromagnet you can make by wrapping wire around a nail.
Inside the fan motor are two windings.
Winding 1 for low speed.
Winding 2 for medium speed.
And when both windings are combined, that makes high speed.
You have to test your switch.
Usually the hot lead connects to red. So the red connects to each of the other wires.
Then pull the chain and use continuity tester between red wire and other wires to see how the switch is set up.
Jun 27, 2011 | Westinghouse Electric Westinghouse...
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
Too fast idle running speed.
Typical idle for this motor is right around the amount you have described. Check to see if any check engine lights are on, or if the ABS light is on. A typical issue with this motor is the OVP relay that when not operating properly causes the engine to rev much too high (~1500-2000). Also do your revs drop significantly when you put the car into gear? If not then there really isnt an issue. When the motor is idling too high and you stick it into gear the car will typically lurch really hard.
Jan 19, 2009 | 1986 Mercedes-Benz S-Class
Ge motor c474
Typical Diagrams Will Be As Follows
C - Common
H - High Speed
L - Low Speed
_____________
W/white - Common
B/black - High Speed
R/red - Low Speed
Apr 09, 2008 | Kitchen Ranges
Maximum range
Since wireless networking uses radio frequencies to communicate between your computers and networks, the maximum distance that 802.11b can operate depends on environmental factors that will affect your network: 802.11b Typical Outdoor Coverage Area 802.11b Typical Indoor Coverage Area 590' 11Mbps 50' 11Mbps 984' 5.5Mbps 125' 5.5Mbps 1476' 2Mbps 150' 2Mbps 1800' 1Mbps 200' 1Mbps
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Taylor Pneumatic: Angle Polisher:. 2500 Rpm. Air Pressure: 90 Psi. Air Inlet: 1/4" Npt Logo
230 people viewed this question
Top Taylor Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Taylor Tool and Hardware - Other Expert? Answer questions, earn points and help others
