Question about Remington Polesaw Wizard
Power source problem
What kind of power source saw should I use?
  • Anonymous Oct 12, 2008
    replace pull cord on husqvarna chainsaw
    President:
  • 2,712 Answers
Gasoline-powered chainsaws use a two-cycle engine (requiring mixing of oil and gas). Mobility and power are the main advantages of gas. Disadvantages include the bother and smell of mixing oil and gas, pull cord starting and the additional overall maintenance needed. Electric saws are great for smaller yard chores. They're quieter than their gas-powered cousins, lightweight, easy to start and require less maintenance. However, they have less power than gasoline-powered saws. They also add the bother of dragging a cord around behind you.
Posted on Aug 27, 2008
Where can I get a 12V manual reset relay which requires reset after a power failure during the on setting?
Get an ordinary 12v single pole relay. Connect your 12v battery source to one side of the coil (-) and one of the contacts (+). Then connect the other side of the coil (+) to the other contact, and your output cable across the coil. Of course, nothing happens until you connect a pushbutton switch ACROSS the two open contacts. When you make that switch, you power the relay, and it stays powered when the contacts close. It's called a "seal-in" relay. When you interrupt the battery power, the relay falls out and won't pull in again until you hit the reset switch.
Apr 23, 2017 | Delta Woodworking Delta Rockwell 14 Inch...
BOSCH RS15 SAW WILL NOT WORK, DOESN'T TURN ON AT ALL.
Check your power supply if have a supply input to the motor of your saw,check also the fuse...if no problem in your power source/supply you can browse or check this site to get some information or guide on how the saw function
http://www.ereplacementparts.com/bosch-rs15-060164e064-114-reciprocating-saw-parts-c-128_1131_7890.html
Mar 10, 2011 | Bosch RS15 1 1/4 Reciprocating Saw
I moved my delta table saw from one place to another and it is not the same i notice that it is much less powerful i conected the same way it was before i would like to know whst could be wrong.
Make sure you didn't go from a 220 power source to a 110 source. Longer extensin cords, especially smaller gauge cords will reduce power to the saw. Harder on the motor too.
Jan 14, 2011 | Delta Saws
What kind of power source does thee del3331-33ub use show me picture 0f power source cable
Hello, this device self feeds from the USB cable, doesn't need any kind of power cable.
Thanks
Jan 11, 2011 | ID Tech DEL3331-33UB
What kind of oil do i put in remington power cutter 3.25
Use regular chain/bar oil available from home centers, hardware stores, and saw dealers.
May 31, 2010 | Remington Electric Chain Saw
I get no power - no LED lights up - does that mean a bad power supply?? I saw a message board with all kinds of comments but all from 2005
Yeah it seems that there is not power. Try plugging the monitor to a different power source and check whether it works. If not then it could be the power supply of the monitor which is faulty.
Nov 03, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
HNF7167 Hoover Washing machine no spinning
how do i put the belt on my washing machine
Dec 07, 2008 | Hoover AAA160 Front Load Washer
Remington Polesaw Wizard Logo
221 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
