Question about Briggs & Stratton Power Products 1539 Pressure Washer
Electric or Gas?
Electric or gas powerd washer?
    President:
  • 2,712 Answers
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Posted on Aug 27, 2008
Is my maytag electric or gas
Look at the back of the machine. Is it plugged in or does it have a gas line running to it. If it is plugged in with a 240 plug (large 4 prong plug) then it is electric.
May 01, 2016 | Maytag Washing Machines
What type of washer is this? Gas or Electric? Mod#110.26912691, serial # CJ 2125579
Hi Carolyn,
I've never heard of a gas washing machine, so I'd say it's electric.
Apr 19, 2013 | Kenmore Washing Machines
Dryer doesn't heat
Is it electric or gas? Most likely u have a blown thermostat or fuse. Could also be a bad heating element if electric. Or bad solenoid coils if gas
Nov 15, 2011 | GE Spacemaker Washer and Dryer Electric...
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
MY DRYER WONT HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 24, 2011 | Whirlpool Electric Dryer Heating Element...
Can a stackable washer and dryer be both gas and electric?
yes, the washer is electric, and the dryer could be gas, all though i have only seen in a stackable modles that i use to eliver for sears, that it was also electric, thats not to say thatthe anufacure does not make it
Mar 29, 2011 | Washing Machines
Heaters types
there are gas powerd heaters and there are electrical powerd heaters.
Aug 27, 2008 | Raypak BURNER TRAY ASSEMBLY
Candy CMD146 Washer/Dryer
Is the dryer electric or gas? If electric, the heating coil may have burnt out. If gas, check gas supply and then gas ignitor. Good luck.
Jan 28, 2008 | Dryers
Briggs & Stratton Power Products 1539 Pressure Washer  Logo
216 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
