Question about Taylor Pneumatic: 1/4" Front Exhaust Die Grinder RPM:25,000. Air Inlet:1/4" Npt. 90PSI. Wt:5/8 Lbs
How to Protect myself?
How to protect myself while working?
    New Friend:
  • 4 Answers
If you are working in any industrial areas than taking proper protection is a must. There are many places from where you can buy safety gears as like Safety Goggles, Glasses, fire protection, eye gears and many more.
If you want to keep yourself safe during your work than adopting this safety equipment is necessary. I personally suggest you visit one of the best online source i.e BRW. Here you will find all the safety products easily.
Posted on Jan 09, 2018
    New Friend:
When operating any heavy equipment, you should always wear the necessary safety gear, clothing, gloves, and I would suggest wearing a good pair of anti-fog safety goggles with an anti-scratch lens to help make sure you can clearly see what's in front of you. North By Honeywell Adaptec Safety Glasses With Transluscent Black Frame...
Posted on Jan 28, 2017
  • 2,712 Answers
When running a die grinder, it is important to follow some simple safety rules. Never wear loose jewelry while operating the grinder. Neck chains can easily become caught in the die grinder and cause strangulation. Safety goggles should also be worn at all times.
Posted on Aug 27, 2008
How do I protect myself from the OpennSSL version 3 vulnerability called the POODLE Attack?
Unless you're running a server, you are not impacted. If you are running a server, you can completely disable SSL v.3.
Oct 17, 2014 | Computers & Internet
Why do people use sink mats?
I have because I want to protect my good dishes from getting cracked or me dropping them and having them break. Its also to protect the sink from getting scratches from the dishes.
Jan 10, 2013 | Home
I have recently receieved No Audio from my SA-DX940 stereo. Is there something I can fix myself to help avoid destroying the stereo completely? Thanks, Scott K.
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Aug 12, 2011 | Technics SA-DX940
My reciever went to protect mode after my speaker wires touched. I removed all cables and power for an hour but stays in protect mode. I also changed 2 15 amp fuses inside but nothing unless I take fuses...
Yes, you can do this easily.
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
Nov 23, 2017 | Onkyo TX-SR806 Receiver
First, disconnect all speaker wires from the unit and power it back up. If it does not go into protect. post a comment and I can walk you thru troubleshooting. If it goes into protect, it needs to be serviced.
Jun 24, 2009 | Sony STR-DE835 Receiver
Receiver stuck in protect mode
surely i can reset this myself without paying sony!
Feb 01, 2009 | Sony STR-DE545 Receiver
My stereo
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
Aug 31, 2008 | Sharp CD-BA200 CD Shelf System
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>>
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
My receiver is in protect mode.
The units in the protect mode because the Microprocessor detects a large current being drawn by the amp. section of the reciver. This is a solid state unit and there are no user replaceable parts inside this unit. Unless you know how to trouble shoot sloid state devices then you should seek a pro to assist you with this repair. GOOD LUCK
Jun 25, 2006 | Sony STR-DE597 Receiver
Taylor Pneumatic: 1/4" Front Exhaust Die Grinder RPM:25,000. Air Inlet:1/4" Npt. 90PSI. Wt:5/8 Lbs Logo
490 people viewed this question
Top Taylor Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Taylor Grinder Expert? Answer questions, earn points and help others
