SOURCE: I am unable to setup may router. I forgot my
You said that you reset the router.
So you will need to reconfigure the router.
You can do it manually. It is very easy.
Click Here for step by step solution
SOURCE: have a d-link router with password. Ipod touch(8G) won't connect
Try remove the password on D-Link router, put it on open conditions (no security enabled).It should work.
If still won't connect, try using laptop or any wireless device to connect to router(without password), if connect, then there's something wrong with your Ipod.
SOURCE: F5D7234-4 unable to connect to internet with
If you are locked out of the router you will need to reset it. There will be a small button (usually at the back) with reset wrote beside it. You will probably need a paper clip or something to push it.
Next to the power supply connection is a pinhole Reset button. Disconnect all cords from your router except the power cord. Press Reset button with a pin for 10 seconds. Wait 10 more seconds then unplug router. If it is then reset to the original factory settings you will have to reinstall it using software that came with router. You may have to reinstall your network card software as well.
Some, but not all, routers have a reset button. Different routers require different steps to perform resetting. On many of them, to restore your own "personal setup" that was created when you first installed the router - not the original factory settings - you just have to disconnect the power supply and reconnect it after a minute or two. You will need to locate and read the manual if you cannot get to Belkin's support site online.
Please let me know if you have any further questions or concerns.
Thanks.
SOURCE: motorola router vg320 problem-- forgot login
broadband.motorola.com/noflash/customer.../516587-001-a.pdf
http://www.answersthatwork.com/Download_Area/ATW_Library/Networking/Network__4-List_of_default_Router_Admin_Passwords_and_IP_addresses.pdf
Top site is for your manual, below that is a lost password list.
SOURCE: I forgot the password to
WIRELESS
SECURITY ISSUES
IF THE ROUTER CAME WITH A BELKIN ROUTER MONITOR .... PLEASE UNINSTALL IT
FROM THE CONTROL PANEL
Step 1 : Connect Router - Computer (
Wired)
Step
2 : Open Router Setup by typing http://192.168.2.1 on the address bar
of internet explorer
Step 3 : On the left under wireless click wi
- fi protected setup
Step 4 : Leave the password blank and click
on submit
Step 5 : Disable it and Click on apply changes
Step
6 : On the left under wireless click Security
Step 7 : Enable 64
Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each
box )
Step 9 : Click apply changes
Step 10 : on the left
under wireless click channel and SSID
Step 11 :Change the
Wireless channel to 6
Step 12 : Change the SSID to a different
name ( no Spaces )
Step 13 : Click apply changes
Step 14 :
Now Scan and connect to this network ( Wireless )
Let me know if
it works
