Question about Viking Die Grinders: 1/4" Heavy Duty Die Grinder
Motor Speed Question
What RPM do I need?
    President:
  • 2,712 Answers
The RPM rating of the die grinder is the deciding factor in the tool’s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
Posted on Aug 27, 2008
I have a model VT 618902aj, its from 1996. What are the pulley sizes supposed to be? Is this unit matched with the present unit mentioned? Thank you
The pulley on the compessor only came in one size ~ about 10 inch. The motor size pulley would depend on the speed of the motor. To get a good volume of air, the pump needs to turn about 800 to 1000 rpm(most pumps have max rpm at that range, good idea to check ). Gas engine turns at 3000 ~ 3600 rpm so use about 3" pully or determine by counting the number of turns of motor/engine to make one revolution of the pump. Electric motors will turn 3450 or 1725. Choose pulley to turn pump at desired speed below max pump rpm and capacity of the motor.
Aug 20, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
High --1600 rpm ?? rpm idle
The normal idle speed is below 1,000 rpm...between 800 to 900 rpm. I suspect that the idle-air control motor has seized and can no longer automatically adjust the engine's idle speed. This part is also responsible for slightly increasing idle speed when the airconditioning is switched on to compensate for the added engine load. Some cars even have a "step-up" solenoid to increase idle.
When replacing the idle-air control motor, remember to clean the port that IAC motor goes into; there will be some carbon build-up that may prevent the part's cone-shaped valve from seating properly. A can of intake valve spray helped along with some Q-tips works well.
Hope this helped.
Have a great day !!!
Apr 07, 2011 | 1992 Buick LeSabre
Playback on the turntable is sped up
The first step to resolving this issue is to select the appropriate RPM speed for the record that you have in hand. If it is not a simple 33 1/3 RPM record set on 45 RPM, then it would seem that the phono motor speed could require adjustment. Your phonograph is a belt-driven PX-E860 K with a DC servo motor.
Some people mistake the the 7"/LP record size LEVER for the rotational speed BUTTON (33 RPM when raised; 45 RPM when down).
In the case of needing to actually callibrate the rotational speed, underneath the unit there is a hole labeled "33" & a hole labeled "45." Using a very fine precision screwdriver, you can callibrate the speed of each. Insert the screwdriver into the repsective hole past the rubber & slightly turn the screw (rotational speed increases as you turn the screw clockwise).
Jan 07, 2011 | Aiwa Z-L500 Shelf System
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Idle at 250 rpm
Idle Speed Control (ISC) Motor OPERATION Eagle Throttle Body Fuel Injection (TBI) System NOTE: The Eagle TBI system is used only on 2.5L Premier engines. The Idle Speed Control (ISC) motor is mounted to the throttle body and controlled by the PCM. The throttle lever rests against the initial adjustment screw of the actuator (plunger). The idle speed is not adjustable. The initial adjustment screw is only used to establish the initial positioning of the actuator when the ISC motor has been replaced. The actuator extends or retracts to control engine idle speed and to set throttle stop angle during deceleration. Based on inputs from the various engine control system sensors and switches to the PCM supplies current to the ISC motor to adjust the actuator position for the particular operating conditions.
Aug 05, 2010 | 1995 Dodge Spirit
More RPM Issues for Tools 1) Have old jointer with motor..1725rpm 5 1/2" pulley.. pulley on jointer is 2 1/2" ..what is 4" jointer blade speed ? also looking for right speed for 4" jointer.. 2)...
I had the same problem a while back, But I didn't bother with exact speed, what I cared more about was power and speed, and not bogging down. And I had it running smooth. Of course I have no idea what the pulley diameters were, but it sounds like you should be real close with the 2 1/2 inch at the head and 5 1/2 inch at the motor spinning 1725, should be about 900? So to get 700, bring the 5 1/2 down to 4 1/2, see if it has enough speed/power.
Feb 13, 2010 | Air Tools & Compressors
Need to find correct pulleys Motor 1725 RPM 5 and 1/2 inch pulley arbor/shaft to attach wheel 3 and 1/2 inch arbor will have 14" buffing wheel need 730 RPM of buffing wheel or close to this less is...
What happened ??? Didnt you get my answer? Was it not acceptable?? What part did I miss? Did you read it at all?? Here it is again for your convenience.
____________________________________________________
HI danmonty007,
Before we go any further, please understand I have no knowledge of any previous history on your question; I have never seen your question before.
Given the information you provided here is the answer:
Motor = 1750
Buffer = 400 to 600
Pulley A = 5.5
Pulley B = 3.0
With the equipment you have, the smaller pulley goes on the motor while the larger pulley goes on the buffer. The end RPM of the wheel (regardless of the diameter) with this equipment is 1114.6 RPM.
The ratio you have is about 3 to 2 while you probably need a ratio of about 3 or 4 to 1. Said differently, you want 1750 to reduce to about 500.
A two inch pulley on your motor would give you a speed of 636 RPM.
A 1.75 inch pulley on the motor will provide you with 556.8181818181 RPM on the wheel.
Understand, the wheel will be a constant RPM but different parts of the wheel will travel at different speeds. The outside of the wheel will be turning around the axel at the same rate as the inside (toward the center) of the wheel. The same number of revolutions ... HOWEVER - the speed of the buffer at 7 inches from the center will be much higher than the speed at one inch from the center. The approximate speed at the outside edge of your 14 inch buffer disk is 3951 inches per min. At one inch from the center, the speed is close to 2800 inches per second. Im pretty sure my numbers are correct.
So, you need a smaller motor pulley to actually get what you want. You could get a bigger buffer pulley, but small pulleys are less $ than big pulleys.
I hope this helps you .
Thanks for your interest in FixYa.com
Feb 13, 2010 | Welding Tools
Have 1750 RPM motor with 5 1/2 pulley to run a arbor shaft that has 3 1/2 pulley.. via belt. wheel that I need to control speed of is 14" buffing wheel. prior post gave calculation website that did not...
HI danmonty007,
Motor = 1750
Buffer = 400 to 600
Pulley A = 5.5
Pulley B = 3.0
Low rpm on blower motor
The 1350 RPM Speed is for 50HZ. The motor will only run at 1525 on 60 HZ.
Nov 30, 2009 | Dayton Shaded Pole Blower 480CFM. 2 Speed,...
Motor & pulley
It would take 6" pully w/ a 2.25" which would not fit on that machine, no room for the 6". Replace with the same RPM motor is the proper way, unless you simply want a slower speed sander, duh! You cannot change the motor rpm without a defenant power issue, if you change the rpm your sander will power out, sorry?
Mar 30, 2009 | Tools & Hardware - Others
Viking Die Grinders: 1/4" Heavy Duty Die Grinder Logo
419 people viewed this question
Top Viking Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Vernon Taylor
Are you a Viking Grinder Expert? Answer questions, earn points and help others
