Question about Makita Rotary Hammer 450 Rpm, 2500 Bpm, 9.6 Amp, ModelNo. HR4000C
Drive systems Question
What is the difference between the drive systems?
    President:
  • 2,712 Answers
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Posted on Aug 27, 2008
  • Robert Lewis
    Robert Lewis Jan 05, 2014
    I bought two when I bought my hammer drill that had a 3 jaw, standard chuck. I ended up cutting off the portion where the slots were and using the bits that way. Work fine.
Why replacement harddrive wont install operating software
If it is a new hard drive it could need formatting or if it already has software loaded it could need the drive formatting on a different machine.
I have noticed something strange, probably in the bios settings of one computer I had contact with recently. It resisted all attempts to load an operating system on an empty drive but loading an operating system with a different machine and then reinstalling the drive in the original it accepted the new operating system without any further hitches.
Another thing to think about was the time we tried to take a look at a hard drive and all my friend's machines refused to read it.
It turned out his machines had 32 bit operating systems and the fresh hard drive was on 64 bit.
Mar 14, 2015 | Gateway nv Computers & Internet
Software
there isn't any software for a USB drive, the system should just see it just like any other USB drive. Try moving the USB cable to a different port. That fools the system into thinking it a different drive & forces the USB drivers to reinstall.
Apr 19, 2013 | Acomdata Computers & Internet
Good day I am in need of drivers for an LG external HDD hxd7.Reason being my laptop will not recognise the hdd but sometimes it does.
Hi
You do not say which operating system you are using.
You do not say which type of computer this is (laptop or desktop).
Most operating systems do not need extra drivers to recognize a hard drive. The drivers are almost certainly already built into your operating system to operate almost any hard drive.
It could be a faulty USB port (try a different USB Port) or a faulty USB cable (try a different USB cable).
If the cable and port are not the problem, then either the hard drive itself or the hard drive enclosure are faulty (open the enclosure and test the hard drive in a hard drive dock or another (custom) external hard drive enclosure.
I hope this helps.
Aug 29, 2011 | Computers & Internet
My sandisk 8 gm is not open , when i try to open it as me that the disc drive is not formatted, do you want to formatte it now ?. what i will do. please help me becouse it inculded important office file...
The reason for which you are not able to open the pen drive is that Pen drive was formatted on a different computer with a different file system from a different OS and then the file was copied into it. And the computer on which you are trying to open the pen drive is having probably different OS which does not support that file system Pen drive was formatted with.
So all you have to do is to open the Pen drive on a computer that has OS same as on which file was copied into.
Thanks
Dec 08, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Jun 14, 2010 | Ricoh 2GB Printer Drive (SCSI-50PIN)...
How can i save my project to external hard drive..? because when i'm trying to save it, there is a notification that my external hard drive can't modified. my external hard drive is just find with any...
Different operating systems use different file systems. Normally they can't use other ones than their own. To write on NTFS file system (Windows) a Mac needs a special program - get it from here http://www.macupdate.com/info.php/id/26288
Nov 27, 2009 | Computers & Internet
Wont play dvd after changing different blue rays
The blue ray drives are system specific. You won't be ablt to just trade oout the drives, you need to keep the logic board from your old drive and put it on the new drive. They all have a code that matches the motherboard and dvd drive logic board.
Nov 03, 2009 | Sony PlayStation 3 40GB System
My cpu doesn't recognized maxtor external drive
Try connecting external drive in different usb ports at the back of computer. Also try connecting on a different computer to check if issue with drive or with computer. If drive came with drivers media ,try installing driver and check.
Aug 18, 2009 | Computers & Internet
Emachine t5026 boots only with os disk in drive
Emachines don't use the cable select properties very well. Change your drive to Master, reformat and reinstall the operatiing system.
Apr 10, 2009 | E-Machines (T2958) PC Desktop
Need to install my new dvd writer on my dell dimension 9200 pc. The plugs are different. now what?
If the plugs are different most likely you bought a SATA drive. If your MB doesnt support SATA then there really isnt any use for that drive, i would return it and purchase an IDE drive, chances are thats what you have. Good Luck!!!
Aug 04, 2008 | Computers & Internet
Makita Rotary Hammer 450 Rpm, 2500 Bpm, 9.6 Amp, ModelNo. HR4000C Logo
388 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
