Question about Hitachi Rotary Hammer Kit 15/16,SDS, 0 4200 BPM,500 W, 5.7 Amp
Speed Qeustion
What speed should I use?
    President:
  • 2,712 Answers
Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes.
Posted on Aug 27, 2008
Error 22-23-26
Precor Error Code 23
Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Precor Error Code 22
Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  4. Damaged speed sensor target.
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Precor Error Code 22 Precor Error Code 23 Precor Error Code 26
May 13, 2014 | Precor C964 Treadmill
9.31 precor error 26 and loud noise
Model: All Models
Recommended Action:
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
Dec 16, 2013 | Exercise & Fitness
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
What does Err26 mean?
Model: All Models
Recommended Action:
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
What is an Error 22, 23,and 26 on a precor 9.35?
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
Error 23 indicates that the speed sensor signal was lost while the treadmill was in operation
Error 26 this error monitors the speed sensor signal and verifies the the speed sensor signal is appropriate for the requested speed. If the speed sensor signal is incorrect or erratic an Error 26 will be displayed.
Unplug unit and remove motor shroud and try these procedures:
The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. The speed sensor position relative to the speed sensor target is incorrect. The speed sensor potentiometer adjustment is incorrect (when equipped). The speed sensor target is damaged
Carefully, vacuum out the drive motor compartment with a static safe vacuum cleaner. Pay special attention to the area between the speed sensor and speed sensor target. Adjust the speed sensor position so that the space between the speed sensor and the speed sensor target is 3/16 inch and so that the speed sensor photo eye is aimed at the larger portion of the targets wedge shaped section. On hall effect speed sensors (magnetic sensor) the space between the end of the speed sensor and the flywheel tooth should be 3/16 inch. If the treadmill utilizes a speed sensor potentiometer, locate the speed sensor potentiometer on the lower PCA. Set the speed sensor potentiometer at mid-range. Start the treadmill and increase the speed to 6 mile per hour. Carefully adjust the speed sensor potentiometer to the point where the treadmill is operating the smoothest. Increase the treadmills speed to full speed at repeat the previous adjustment. These two adjustments are typically small and are usually only a matter of fine tuning. . Most speed sensor targets consist of a circular arrangement of alternate black and silver sections. If the speed sensor target is torn or badly scratched the speed sensor may receive an incorrect reading. Replace the speed sensor target.
Jun 25, 2010 | Precor 935 Premium Series Treadmill
I need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Hitachi Rotary Hammer Kit 15/16,SDS, 0 4200 BPM,500 W, 5.7 Amp Logo
139 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
