Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Playing MPEG's How Do I Play Back An MPEG Recording?
    Master:
  • 473 Answers
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Posted on Sep 06, 2005
I DID NOT USE MY TVR460 VIDEO CAMERA FOR 3 YEARS. NOW IT IS NOT RECORDING OR PLAYING ANY TAPE. IT CAN RECORD AND PLAY ONLY ON SONY MEMORY STICK.
Recording / Playback head is metal with a thin gap which quickly becomes corroded from simple condensation - unless stored with water absorbent material in airtight container. Sorry, (you needed a newer model anyway) ;-'
Sep 19, 2016 | Sony Cameras
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
Videos stop and start. How to fix
It is called buffering. The video's tend to play and stops at some point and then continue playing because it is still loading the video. Just wait for the video to load completely before playing. You will notice this thru the red indication bar align with the play button. If the loading does not finish, try reloading the webpage by pressing F5.
Hope this helps. Thank you for using FixYa.
Dec 20, 2010 | YouTube Videos
Playability of mpeg4
YES, IT CAN
no kidding, use mpeg converter, you will find it can convert any video format to mpeg, rock and roll
How to change the recording video type to MPEG?
Mpeg format is very popular for its wide-ranged compatibility with video editor and media player, and its cross-platform neutral capability, meaning the mpeg format can be easily handled not only by Windows OS, but also on Mac. Mpeg is a compression codec used to reduce the space video files take up without severely compromising image quality. And MPEG-4 is the global multimedia standard, delivering professional-quality audio and video streams over a wide range of bandwidths, from cell phone to broadband and beyond.This could explain why so many people choose mpeg format for video editing purpose. It is also no surprise that people would ask about how to change the recording video type to MPEG format or how to convert mpeg to other formats.
Mpeg converter is born to solve the mpeg related conversion problem. Mpeg converter can convert almost all kind of video formats to MPEG file, such AVI, WMV, ASF, 3GP, MOV, VOB, MPG/MPEG2 and FLV (Flash Video), which could be converted/exported as avi, mpg, mp4 video formats for your later options, while keeping the original video quality. Mpeg converter can also extract audio track from those supported video to m4a, mp3, wav audio formats. besides, it is a powelful video editing tool too. Mpeg converter lets you trim any splendid clips or episodes of your favorite videos, crop the unwanted black edges of video, apply video effects, and capture pictures from your video.
i am sure this will be a total fresh experience for you, things will be easier if you follow the tutorial below:
step 1. Click here to download, install and then run Mpeg converter
step 2. Select a format to load video info
To load video info, click Load File button. you can choose one video or more each time at will with the batch conversion capability. define the output path by clicking the output button, you can then name the output file as you like.
step 3. Tune settings for the output video/audio
a. Click the Edit button to edit effect (Brightness, Contrast and Saturation).
b. click Trim button to decide which part of the video you would like to convert using slide bar to specify exact the start time and ending time.
c. For more settings click Setting button to tune the video/audio parameters like frame rate, bit rate, resolution, etc.
step 4 Start conversion
after all the steps above, you are noe set. click start button to feel the fast conversion speed.
Nov 26, 2008 | Sony DVP-NS575P DVD Player
Video down load problem
It sounds like your computer doesn't have an MPEG-2 CODEC installed. Windows doesn't come with one on its own, you generally have to have something else installed, like a DVD player application WITH a DirectShow MPEG-2 filter. That's the usual reason for a video file playing audio-only... the video CODEC is missing.
You would think this would be on the disc that comes with the camcorder. Do they have any video player or editor of their own? Did you try it?
Anyway, you can get a free (open source) DirectShow MPEG-2 filter here: http://sourceforge.net/projects/gplmpgdec. Download and install this, and... assuming you're using a compatible version of Windows, you will probably be able to play back the video in Windows Media Player.
In the future, it's a good idea to indicate things like the computer OS you're using, version, the kinds of programs you're trying to use, etc. That will help folks like me pinpoint your specific issue.
Jan 18, 2008 | Sony Handycam DCR-SR82 Camcorder
How do I pause while recording?
As far as I can tell, and yes the documentation is skimpy, when you press the 'record/play' button the video recording pauses. Make sure you press the video icon button, not the 'record/play' button to get it started again. If you press the 'record/play' button, it goes into a 'play back' mode.
Hope this helps...
Dec 26, 2007 | Jazz DV-179 Digital Camera
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
66 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
