Question about Porter Cable 75300 Height Adjustment Knob For 7539 Plunge Router
How to adjust the collet easily? - Porter Cable 75300 Height Adjustment Knob For 7539 Plunge Router
    President:
  • 2,712 Answers
Look for a button that will lock the collet in place. This will allow you to adjust the collet with a single wrench, without having to wrestle with several wrenches.
Posted on Aug 27, 2008
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
The collet seems jammed and I cannot adjust...
This is just a longshot, but look down inside the chuck with a flashlight and see if your chuck-mounting screw has migrated out. I had the same problem with my Milwaukee, and turns out that's what it was. The collet was jamming up on the chuck screw.
May 02, 2011 | Black & Decker & Cordless Drill
Dremel 300 Series - I can't get a collet to go in the shaft. looks like something the same size is in the shaft but is not proturding to pull it out. Unable to wedge it out.
There is a collet stuck in there. It was probably in there without any tool in place, then the collet nut was tightened. With no tool filling the hole in the collet, it collapsed and became small enough to be pushed too far in. Fortunately these collets are soft steel. Find a sheet metal screw that you can screw into the hole. That will allow you to pull the collet out. Discard that collet. These collets come in at least two sized to accommodate different sizes of tool shafts. Unfortunately the spare one you have is one of those sizes, and the one you extracted is probably the other. But they don't cost much and you can buy them where you buy dremel tools. Good luck, Al K
Feb 02, 2011 | Dremel Variable - Speed Multipro Rotary...
Bit wont tighten down in collet
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
Oct 19, 2010 | Hitachi M12V2 3Router
The collet seems jammed and I cannot adjust the size to fit the drill bit
web search-black and decker repair manuals- they have site for parts,repair guides and diagrams
Oct 06, 2010 | Black & Decker & Cordless Drill
I have a brand new Ryobi router model ERT241200. Am I supposed to insert the 1/4'' collet into the cavity where the collet nut is, then insert the bit into the collet and tighten the collet nut? I thought...
Do you have the collet upside down? It should fit in nicely and the lock nut fit over the top, no problem, If it doesn't, something is wrong. They only make 2 sizes of collets for router bits, 1/4 and 1/2 , if they get their parts from somebody who makes just collets, you could have easily gotten a different size in there. See if a router bit will fit the hole, then go to the store where you bought the router and ask them to try it in your router and see if it fits, they might have collets on the shelf. Check it out.
Jun 03, 2010 | Ryobi Tools & Hardware - Others
Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Dec 05, 2009 | Freud FT2000E 3 Router
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Jun 27, 2009 | Dremel Variable - Speed Multipro Rotary...
Porter Cable 75300 Height Adjustment Knob For 7539 Plunge Router Logo
213 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
