Question about Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw
Blade type what are the uses of differant blades?
    President:
  • 2,712 Answers
Blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
Posted on Aug 27, 2008
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
What size blade duds it take
You can measure the length of the blade or take it off and go to a store and get a mulching blade it doesn't have to be a Poulan Pro
blade a generic mulching blade of the same size will work and be cheaper. Tractor supply handles a lot of different types of blades.
Jun 17, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
Is a reamer better than a juicer?
The reamer itself is considered a type of juicer, as one of the methods of producing juice is with the use of a device characterized by a conical blade with deep troughs running its length.
However, if by reamer we mean the original tool, with its blade attached to a handle rather than positioned over a small bowl, there is in fact a difference.
Both tools function on the same principle: a blade twisting inside the fruit to extract the juice. However, unlike original reamers, what we may call a reamer-based juicer is sometimes powered electrically, with its blade turning automatically, and sometimes manually, by pushing the fruit on the blade and turning it. Moreover this type of juicer provides an easy storage of the juice, in its little bowl sitting under the blade, and automatically strains the liquid removing most of the seeds and unwanted pith.
On the other hand, a manual reamer must be twisted by hand from its handle, and the fruit's juice must be carefully dropped in the proper location, be it a cup or a bowl, and consequently strained.
Therefore I believe that a reamer-based juicer is more convenient and easier to use than an original manual reamer
Oct 08, 2013 | Home
What are the different types of fan blades available?
There are few types of fan blades that include:
Traditional
Industrial
Decorative
Outdoor
For more details on these types of fan blades, check out this website: http://www.ehow.com/list_8026115_fan-blade-types.html
Feb 07, 2013 | Emerson Fan Motor & Blade - 1/6 HP
Roybi sawzall blade wont go in
be sure it is rite type of blade some are pop in and some have a set screw there are several different blades for these couple different types of tools hope this helps
Mar 02, 2012 | Ryobi 18 V Cordless Reciprocating Saw
I bought a second hand Power Devil Mitre Saw PDW 5013. It has no instruction manual and I need one.On starting up the saw, the blade spun but sounded terrible, loud and not right. On trying again, several...
Try the blade first. It should be tight and have no real wobble to it. Although my first guess would be the brushes, These are generally accessible from the outside. There is often a number or something to identify the brush so that you can get a proper replacement pair. If the motor starts right away and the blade does not then the blade is loose. re- reading your post it could well be the blade. Often these are reverse threaded, so you tun them clockwise to get it off. You may well want a new blade anyway, and there are different types for different jobs. Watch your fingers and unplug the saw when messing with the blade- it is easy to hit the switch when undoing the blade.
Jun 10, 2011 | Saws
Blade acts unusual
Hi, Blade wobble at high speed can be very dangerous! The saw at the right ( wrong) wobble can destroy itself.There are a few things that can cause it, And you have to check them as best you can before you power it back up. Check the blade, you can lay two blades together and check for gaps anywhere. Check that the hub and spindle are flat where the blade goes. (No lock washers) Also check the spindle for side to side movement, there shouldn't be any. Turn the spindle by hand and see if you feel any grit or sandy type feeling, you shouldn't. Lastly, if you don't find anything, try a new blade of a different type, and if it wobbles again, check and see if you have any warranty left and even if you don't you should contact Makita about it.
About the best I can do from long distance. Let me know what you find, Please.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 31, 2009 | Makita 10" Compound Miter Saw LS1040
Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw Logo
335 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
