Question about Jet 708315BTC Jbts 10BT 3 15 Amp Benchtop Table Saw
Blade size what is the blade size for me?
    President:
  • 2,712 Answers
There are two common blades: Eight-Inch Table Saws are a good choice for crafts and other applications associated with thinner stock.Ten-Inch Table Saws provide the extra cutting depth needed for angled cuts in thicker stock.
Posted on Aug 27, 2008
Makita slide compound- Saw Blade. LS0714
It seems as though the original blade was fitted without a spacer. These usually come with any new blade. It is simply a washer (usually aluminium) that fits in the hole of the saw blade and reduces the hole diameter down to the size of the flange on your saw. This is common practice. Never try and centre a blade without the correct size hole to flange size. Very dangerous. These washes are really cheap and can be obtained from most hardware stores. Usually in an assortment of different outside and inside diameters to suit any circumstance. Hope this helps, cheers Bob.
Oct 26, 2016 | Makita Saws
I have a 91Murray 42inch riding mower need proper size belt to run blade,a blade belt
Contact a local auto parts store, a full service one, bring in the old belt and they can match it.
Jun 23, 2016 | Murray Garden
I cant seem to find the blade size for an older pro tech bandsaw model 3101. Is there a newer model that is compatible?
There should be enough adjustment on the tensioner to allow you to use any size blade that will be close to the original size. Set the tensioner/adjuster to the mid position measure the size of the blade, and look for one close to that size.
Nov 10, 2014 | Saws
What size blade duds it take
You can measure the length of the blade or take it off and go to a store and get a mulching blade it doesn't have to be a Poulan Pro
blade a generic mulching blade of the same size will work and be cheaper. Tractor supply handles a lot of different types of blades.
Jun 17, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
CHANGING REAR WIPER ON 2008 OUTLANDER
These are available at the dealership. There is one way though. You can get a 21" RAIN X wiper and i just cut it down to size. The grooves on a RAIN X will fit up to your rear wiper. As far as replacing it although it looks more difficult at first glance it it every bit as simple as the front wiper blades. It's a simple pop off. You can also just change rubber wiper and leave the actual blade alone. the rear is a mini blade style (this refers to the size of the rubber insert in the blade, not the actual whole blade being small.) You can replace the rubber using an Amcor blade or any "mini" blade. Puchase the biggest one they have, take out the rubber wiper and just cut to size. You can change the rubber many times off of one blade thus saving you a bunch of money.
Mar 17, 2011 | Mitsubishi Outlander Cars & Trucks
Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Apr 22, 2009 | Oster 76076-010 Hair Trimmer
What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
Do not forget to rate, please.
Mar 12, 2009 | Watches
Size of hole in 10inch blade for dewalt power workshop radial arm saw
The size of the hole directlly relates to the size of the blade that fits on the saw, do not change blade sizes it is dangerous and will not fit properly
Mar 10, 2009 | Dewalt Factory-Reconditioned DeWalt DW432R...
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Jet 708315BTC Jbts 10BT 3 15 Amp Benchtop Table Saw Logo
128 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
