Question about Jet 708315BTC/JBTS - 10BT - 3 10 Benchtop Tabl JBTS - 10BT - 3 10 Benchtop Tablesaw
Table saw blades maintenance
How do I clean the buildup off my table saw blades?
    President:
  • 2,712 Answers
You can clean your blades while they're on the saw, but if you do make sure to disconnect the power. An easier method is to clean the blade when you're removing them to have them sharpened. The buildup can be removed using a furniture-cleaner known as buildup remover. Apply the cleaner directly onto the blade, and use an old toothbrush to scrub away the buildup. For stubborn buildup, follow up with some cleaner and fine steel-wool.
Posted on Aug 27, 2008
Motor burn out Rigid R4510 table saw
Rarely you can get a motor that burns up because of bad internal parts and sawdust can lead to problems but motors are designed to handle and placed on the saw in a position to avoid heavy sawdust buildup. In my experience at my repair shop, most table saws that come in for motor repairs are directly attirbutable to using dull blades and making up for that by forcing the work through the saw. If you have a good quality, sharp/new blade and feed the wood into it at a reasonable rate, even a weak motor can get the job done.
Dec 18, 2012 | Saws
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
Oct 25, 2011 | Craftsman 10" Table Saw
Blade is not square to table of 10" cabnet saw is there an an adjustment somewhere
The adjustment for the Delta cabinet saw (Assuming you mean the Unisaw model) is made by loosening the four bolts that hold the cast iron table to the cabinet and adjusting the table to square it to the blade. Make sure you retighten them a little at a time and working on opposite corners as you go so that you tighten them all evenly.
The only adjustments for the blade are the stops associated with the tilt of the arbor. While you have the top loose, it's a good opportunity to clean up the inside of the saw.
Feb 07, 2011 | Delta Saws
I have cleaned the worm and Gear segment for blade raising mechanism on my 66 and it still binds and is stiff. What do I do next?
Try lubricating with silicone spray. I use it for just such things, and I'm happy with how it works. Also, clean and lubricate the lock on the elevation control.
--W/D--
Jan 29, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I can no longer raise or lower the blade on my 10" sears table saw' model # 113.298032.
After some use the threads on the raising mechanism can become clogged with sawdust and resin.
UNPLUG the saw and look underneath up inside the box. there is a rod that runs from the wheel you turn to raise and lower the blade into the actual mechanism. Brush it clean and give it a good douse of WD40 to help clean it. That rod must turn freely so look for any obstructions that will prevent that from happening
Jan 18, 2011 | Craftsman 10" Table Saw
My bosch 4000 will not run at full speed. Not using ext cord and electricity in my home is working.
This is common "affiction" for all table saw... and easy to fix, it applies to all power/hobby table saw in existence regardless of brand, manufacturer or model, if electrical problem is excluded, something is holding the blade:
1. switch off power
2. remove power cord from the socket
3. lift panel in the centre of the table (you did not supply exact model
4. remove nut holding the blade and the blade, pay attention to the direction of the teeth
5. clean bottom of the blade groove from all debris and especially long pieces, slivers, of offcut timber
6. put blade back in place and tighten the nut, check if it is moving freely, check if it is not slipping or wobbly
7. put table panel back, find these two pesky little philips screws which run somewhere on the floor and mount them back as well...
8. connect power and switch on and instantly off, check the blade again for slippage/wobbliness
9. mount back protection gards, try test cut
10. if test cut was successfull, use normally till next sliver fell in...
If test cut was unsucessfull - if this is open motor, check for debris inside ot the motor or even fan, then check brushes on the rotor if they are not carbonised too much or even burnt.
Do remember that this is not a toy, always disconnect physically at power point if you do any maintenance, blade will cut through timber, ocassional nail and through your fingers...
Do always wear googles or face shield, saw produce chipping and splinters while it works, you have two eyes but no spares.
Hope this advice will solve your problem, please do not hesitate to leave note how did you went :-)
Aug 17, 2010 | Bosch Saws
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
I have a skill table saw model 3400 type 2. The
I would check to see that ID of the blade arbor matches the OD of the motor arbor, and you are not missing an adapter ring. Then I would get some acetone and a wire brush clean all surfaces where the blade seats. This is also good practice for Jacobs chucks on drills, that allow the drill bits to spin.
Jim
Aug 04, 2009 | Skil 10" Table Saw 3400
Smoking
Couple things I would look for first the condition of the blade do you see any buildup around the teeth like something has burnt on it. Also look into the area around the blade under the table (unplug saw first) to make sure that something hasn't dropped into it rubbing blade causing smoke. Also turn the blade by hand to make sure turning freely. The smoke could possibly be coming from a bearing. If it less than a year old Bosch has a pretty good warranty and you might look into that also. Let me know and I will dig deeper into it.
Jan 11, 2009 | Bosch 4000 - 07 Electric Table Saws
Jet 708315BTC/JBTS - 10BT - 3 10 Benchtop Tabl JBTS - 10BT - 3 10 Benchtop Tablesaw Logo
173 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
