Question about Dewalt DW802G Heavy Duty 4 1/2 Inch High Power Small Angle Grinder W/ Paddle Switch And Ground Wire
Grinder Usage what are the usage for a grinder?
    President:
  • 2,712 Answers
Grinders are versatile tools that shape, grind, polish, and cut quite a few materials. A grinder can also be used to maintain your other tools that may need sharpening with blades, cutters, or bits.
Posted on Aug 27, 2008
Krups grinder 223
what problem do you have?
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
Ids77 electric coffee grinder I want replace fuse how can I open this prodact please.
see this causes and proceed:God bless you
Sep 25, 2012 | Coffee Makers & Espresso Machines
Display saying GRINDER
my machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Aug 03, 2010 | Gaggia Titanium Espresso Machine
The coffe grinder smell burn after usage. Is there a way to clean it.
You should check you manual for directions as to how to take the machine apart to clean it because it needs regular cleaning. Since you have not cleaned it in a while, the beans are probably getting super hot and burning inside the grinder because of friction. Also, this particular machine operates best with a drier (less oily)coffee bean... think Italian expresso beans. These drier beans should work better with this machine.
Mar 04, 2010 | Saeco Easy Espresso Machine
Bench Grinders Usage
Grinding is the fastest way to deburr a sharp corner or dress the end of threaded rod or bar stock that's been cut to length. Fit a grinder with a wire wheel, and you have a handy tool for removing rust. Then switch to a buffing wheel and you're ready to polish metal to a mirrorlike sheen. But for most of us, grinders are essential for shaping and sharpening hardened tool steel and high-speed steel.
Aug 27, 2008 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Motor Speed Question
The RPM rating of the die grinder is the deciding factor in the tool’s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
Aug 27, 2008 | Viking Die Grinders: 1/4" Heavy Duty Die...
Die Grinder usage
these tools are handy for any finishing or grinder that needs to be done in a small spot.
Aug 27, 2008 | Taylor Pneumatic: 31 Pcs. Sanding Prep....
Grinding Coffee Beans
You go my interest (I gind my own as well but not with a **** ginder), read THIS set of forum posts and maybe try some of the ideas there. Most sites I read said that it goes away with time and usage, but could take as long as a year! WOW.
Enjoy,
Geno
Apr 03, 2008 | Coffee Makers & Espresso Machines
Dewalt DW802G Heavy Duty 4 1/2 Inch High Power Small Angle Grinder W/ Paddle Switch And Ground Wire Logo
311 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
ken skalski
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
