Question about Makita 841008-A Chain Saw Chaps 38" Waist
Left hand problem
Can a left hand man handle the saw?
    President:
  • 2,712 Answers
Yes, but you lefties especially may want to handle one before buying since they're basically all made for right-handed people.
Posted on Aug 27, 2008
Locked
Sounds like the chain brake is locked. On the front of the saw, in front of where you would put your left hand on the handle is another piece. Its probably plastic. With the saw off, take your hand, place your thumb on the front handle, your 4 fingers on top of the paddle & pull the paddle back toward the front handle until it clicks, thus releasing the chain brake & freeing the chain.
May 26, 2014 | Garden
Sl-yd5200b
If the saw is fitted with a decompression switch you need to decompress the cylinder after every pull to make it easier to start. If it doesn't have a decompression switch you need to put the saw on the ground and put your right foot firmly into the handle opening, place your left hand on the top hand bar, grip the pull handle and pull out slowly until you feel a solid wall or compression and then pull straight up fast and hard for about 8 - 10". Make sure the brake is on when starting. I have an older Husky saw and this is how I start it. It has a short pull cycle so don't try to give it a long pull like a weed whipper!
Feb 12, 2014 | Husqvarna Garden
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
What position should the kick back be in when starting?
Your OM (all manufacturers) says to engage the chain brake prior to starting. It is the safest way to start your saw.
I start my saws on the ground (like the OM recommends), right toe in rear handle, wide stance, left hand on front handle with the chain brake disengaged. The saw I used first (Pioneer 1980±) has no chain brake.
I now have a Mac 110 (top handle) that is very awkward to start on the ground. I engage the brake on it before I attempt a start. Whatever method you use Please exercise great caution.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
How do I change blade on Ryobi W-660 circular saw. I put some WD-40 on bolt, but it doesn't budge. To loosen, I turn clockwise?
I can't find that model number listed but generally a circular saw is standard thread, the mitre saw us left hand and a worm drive is also left hand thread.
Jan 02, 2010 | Ryobi Saws
Locking mechanism on miter saw.
Push down on the handle . Facing the saw there is a spring loaded pin on the left rear side , right at the pivot point , pull out on it and raise the handle to the up position.
Jan 03, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Circular saw Safety issues
If you are left-handed, you must be extremely cautious when operating a circular saw, since most saws are designed for right-handed operation. But if you can, you'll be better off with a left-handed model or an adjustable one (suitable for right-handed and left-handed as well).
Aug 27, 2008 | Bosch 5" 60-grit Sanding Discs for Wood (5...
Makita 841008-A Chain Saw Chaps 38" Waist  Logo
74 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
