Question about Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Chain pitch what is a chain pitch?
  • Anonymous Aug 31, 2008
    Chain slips off sprocket
    President:
  • 2,712 Answers
Chain pitch is the spacing of the rivets on the chain. The saw's sprocket has the same spacing. The normal pitch is 3/8"
Posted on Aug 27, 2008
The chain keeps coming off when I try to use. It may be that I'm not installing the chain correctly. Need help
either that or the chain is badly worn and the chain pitch and the sprocket pitch are now different
get a new chain first
Sep 08, 2017 | Garden
What other chain can i use on a stihl 025
You need to know three things about your saw as to what chain will interchange....1. Pitch of the chain. 2. Guage of the guide bar. 3. Number of chain links.
Your little 025 Stihl wil probably have an .050 guage and a .325 pitch. The standard guages for small saws are .043, .050 with .058 and .063 being reserved typically for the larger displacement saws.
The pitch is the length of three links, divided by two and the number of links is kinda self-explanatory. (The 025 USUALLY is set up for the .325 pitch.)
Any chain that matches the three measurements for your respective saw should interchange. Hope this helped instead of adding to the confustion......
Sep 18, 2015 | Stihl Garden
What causes my 460 chain saw to tear up the teeth on the chain in the clutch
wrong pitch of chain for that saw . sometimes folks bring me a saw that they have no idea what the correct pitch chain is for saw , im lucky n that respect as I got dozzens and dozzens of old chains laying about so I grab a few a try em for size on the ole saw . so my suggestions to you if your unable to do that is to go to a ole chainsaw shop and ask to test fit a few chains for size , saves you from tearin up a clutch sprocket
Jun 29, 2014 | Husqvarna 20" 60cc Rancher Chain Saw 460
My bike chain always become loose ??
Both, chains and sprockets have "pitch" if they are not the same pitch the chain will become tight then loose breaking the bearings and destroying the chain
Apr 01, 2014 | Regina Chain 520 ZRD Chain and Sprocket...
I have husquavarna chain saw s/n 95212H01984 with sticker that says 41 Air Injection. Need to buy chain and/or chain bar. Need to know the model number for this serial number. Can you provide
The saw is a 41, as standard it ran a 15" bar and chain, in the UK it ran a .325 pitch, however in the US, it ran a 3/8 pitch chain, as you should change the sprocket if fitting a new chain, i would put it on .325 if it is not already, the sprocket is part no. 530069342, the 15" chain is 501840664, and the guide bar is 508926164 these are .325 pitch 050 gauge and 64 drive links, this combination will cut much faster than the 3/8 low profile combination.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to know the degree to set my electric chain saw sharpener for husqvarna chain. This is a 20 inch chain.
A 20" bar unfortunately does not narrow it down. Fortunately both the .325 pitch chain and the 3/8 pitch chain sharpen at 25 degrees and you should have one of these chains. Hope this helps.
Mar 01, 2011 | Husqvarna Chain Saw 20" Bar
After new clutch sprocket &good bar &chain chain r bar moves prematuely and chain comes off bar nuts r tight
have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
.325 x 0.50 gauge , .325 x 0.58 gauge
3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
you could even have the correct drum but wrong rim sprocket on it
worst case is you could have mismatch bar and chain
make sure that bar adjjuster assy is working correctly
recheck chain / sprocket pitches and bar pitch and groove
gauge
be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
is the clutch cover pulling down tight ?
have a look and let me know if and what you find
cheers paul
Aug 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need the specifications on a 1996 Kawasaki Ninja Zx6R Rear Wheel Chain. I need to buy a new one and don't know what size/specifications I need.
You need the pitch, roller width, roller thickness (All in all just the chain type) OEM is a 525, 108 link chain with a 15 tooth front sprocket and 40 tooth rear.
It is best to change sprockets and chain together. A stretched/worn chain will damage the sprockets which in turn will lead to premature wear on a new chain.
Best way to identify pitch(and chain type) is to measure the sprocket width(thickness).
  • 0.227" (5.76mm) - 520 chain
  • 0.284" (7.21mm) - 525 chain
  • 0.343" (8.71mm) - 530 chain
Technically speaking they all have the same pitch (5/8") as you can see they are of different widths. Please note that a 420 and 425 have the same widths as 520 and 525 but their pitch is different(0.5")
Further you will have to decide between stock, O-ring and X-ring. X-ring being the most expensive(and supposedly longest lasting) but in my experience lasts the same as an o-ring chain.
Aug 11, 2010 | 1996 kawasaki ZX-6R Ninja
I want to run a 3/8 pitch 0n my 028 do i need to
The following is copied from the Oregon FAQ "What is pitch".
Chain pitch is the distance between any three consecutive rivets divided by two. Pitch defines the size of the chain. OREGON® chain is made in several pitches - 1/4" is the smallest, 3/8" is the most popular. Other parts of the cutting elements are pitch-related. The drive sprocket must be the same pitch as the chain, and so must the nose sprocket in sprocket-nose bars.
An illustration and the original question is here: http://www.oregonchain.com/pro/service/faq.htm
If the result from an existing chain is 3/8"s or 0.375" then you need not replace the sprocket. If the result is different then the drive sprocket and bar nose if sprocketed must be changed. Chain gauge must also match to prevent problems.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 03, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Degree of pitch when sharpening chain on Shindawa chain model 360
It is dependent on the manufacturer of the chain not the saw.
Download this and look carefully at page 9.
http://www.northerntool.com/downloads/manuals/193020.pdf
I think it is exactly what you requested.
I hope you find this helpful.
Lou
Jan 15, 2010 | Garden
Makita DCS51018 18" 45cc Chain Saw 2 Cycle Logo
203 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
