Question about Coleman Powermate 024 0091CT High Speed Air Sander
Speed Control Question
Do I need variable speed Control?
  • morven39 Jan 02, 2009
    Porter Cable 7336 head will not start rotating unless I spin by hand to start it. Would changing the brushes fix this?
    President:
  • 2,712 Answers
When you are finishing the surface of wood, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Posted on Aug 27, 2008
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
Vitamix 5000 variable speed control broken
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
May 18, 2015 | Vitamix 5000 Work Top Blender
I have same problem, no variable speed control for Milwaukee 04201-1, just full speed. Is this electronic speed control as well? If so can I still get parts needed? Thanks
Variable speed on this model is controled by the switch. Part number was 23-66-2300 but it is discontinued. You may be able to use Google to search (by the part number then hit the shopping link on the left side of the page) for someone that still has one in stock.
Aug 19, 2012 | Drills
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
Spin half the speed
Hi.
Depending on the make and model, and type of washer, you may need to test and eventually replace the following parts:
On top loads:
Variable speed motor .
Motor coupler.
Transmission.
Control board.
Motor control unit (if present)
On front load :
Motor coupler.
Control board.
Motor control unit.
On top load the problem is often transmission or variable speed motor. On front load MCU or motor.
Dec 14, 2009 | Washing Machines
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Variable Speed Control is faulty
Unfortunatly Dremel who is owned by Bosch has discontinued that tool and parts are no longer available.
Apr 16, 2009 | Dremel Variable - Speed Multipro Rotary...
Variable speed Control problem
When you are finishing the surface, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Aug 27, 2008 | Vector Vec 260 10 Inch Waxxpro...
Coleman Powermate 024 0091CT High Speed Air Sander Logo
134 people viewed this question
Top Coleman Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Coleman Tool and Hardware - Other Expert? Answer questions, earn points and help others
