Question about Bosch 3X18 Belt Sander
How many Types of Sanders?
What type of sander do i need?
    President:
  • 2,712 Answers
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Posted on Aug 27, 2008
Jane sanders ***** investigations
U.S. Is Investigating Jane Sanders Over Burlington College Bank Loan ...
https://www.nytimes.com/.../jane-sanders-vermont-burlington-college-investigation.html
7 days ago - Federal authorities are investigating a 2010 land deal for a Vermont college that was run at the time by Jane Sanders, the wife of Senator ...
Jane Sanders Lawyers Up - POLITICO Magazine
www.politico.com/.../bernie-sanders-jane-sanders-lawyer-bank-*****-investigation-bu... Jun 22, 2017 - The strange story behind the federal investigation that has rattled Burlington, Vermont, and put Bernie and Jane Sanders on the defensive.
Jane Sanders Bank ***** Investigation: 5 Fast Facts You Need to Know
heavy.com/.../jane-sanders-bank-*****-investigation-fbi-burlington-college-brett-segl... Jun 26, 2017 - Jane Sanders, Bernie's wife, has hired a lawyer to deal with a federal investigation for bank ***** stemming from a loan she sought as ...
Bernie Sanders says reported investigation into his wife stems from ...
www.cnn.com/2017/06/27/politics/bernie-sanders-jane-sanders.../index.html Jun 28, 2017 - Bernie Sanders on Tuesday defended his wife, Jane Sanders, amid reports of a potential federal investigation related to her time helming the ...
Jul 17, 2017 | Miscellaneous
Looking for the manual,my paper slip off as soon as I start to sand the wood
There are a couple of different types of paper you can use with a sander. One with a sticky back and one that works is like velcro . Sounds like you are using the wrong kind of paper for your machine
Sep 04, 2015 | Tools & Hardware - Others
Sanding pad ripped off plate on DW421
You can get a new one fairly cheap. Toolpartsdirect.com there is different types to that model. Once you get it, they are not hard to change, 3 or 4 screws.
Sep 14, 2013 | Dewalt DW421 5'' orbital sander
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
Sandpaper will not stick to rubber bed bosch
This is generaly due to previous adhesive buildup on the backing pad OR, the face of the backing pad is breaking down and cracking.There are two ways to handle this. You can try scrubing the crud off the pad (I wouldn't) or, you can get a new backing pad for your sander. At this point, you might want to go with a velcro type pad or hook and loop as they call it (cleaner and no goop). Check your local home depot for pads. If you cannot find one, I would suggest you call Klingspor abrasives Co. They have area reps all over the United States. I know, as I used to be one of them.They carry,.. and will send you pads via UPS. Just make sure you don't try to put a 6in pad on a 5in sander or vice-versa as the pads are weight-mated to the sanders. If you do, you will burn up the motor in your sander rather quickly.
Jan 24, 2010 | Bosch Power Tools Sanders Orbital Sanders
How do I change the sandpaper in my Black & Decker Sander 7448? I lifted the two levers and the sandpaper came out but now I cannot get them to close tightly around the replacement sandpaper.
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Nov 15, 2009 | Tools & Hardware - Others
Tool is cracked, is it PVC or another type of plastic
I dont know what kind of plastic these sanders are made of. Your best bet is just to try a strong 2 part epoxy. If the epoxy doesn't bond then you should be able to just scrape the glue off and try something else.
Oct 22, 2008 | Makita 9901 3 inch x 21 inch Belt Sander...
Bosch 3X18 Belt Sander Logo
442 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
