Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Drill Turque what is a drill torque?
    President:
  • 2,712 Answers
Torque, which is measured in foot-pounds, is the drill's maximum amount of turning force. Some drills have an adjustable clutch with different torque settings for different applications.
Posted on Aug 27, 2008
I have a cordless drill model 6095D. The torque function is always on torque, won't put in screw. I don't need the torque function at all, just straight screw driving, but need to fix some way.
50% of issues like this one are solved by cleaning the mechanism, you have quite old drill so it's a big chance a metal chip went somewhere between the gears, take the drill apart and clean the mechanism first, if this is not the issue you may figure out by taking the drill apart which you need to do in any case. Or take the risk and use brute force. drillselect com
Nov 12, 2016 | Drills
Drill disengages when spinning
Could be several things. If it is a reversible drill, the selector switch could be stuck between forward and reverse. If it is a variable torque (popular on battery drills) the torque setting could be real low. Also, I've had this problem with the gears inside the drill wear out. No easy fix for that. If it is an inexpensive drill it would be cheaper to replace it than to have it repaired.
Feb 18, 2016 | Drills
My Dewalt DC925 works well but the torque settings don't seem to be working.when i am drilling screws the drill will just drill until i release the trigger.is this a clutch problem?. Many thanks.
Try to put it on the lowest torque and if it slips when wanted, then add a little more torque and check to make sure it slips. Continue at each torque setting and usually works again at full torque. Usually happens when left on the same torque all the time. This kind of resets it.
May 07, 2015 | Dewalt Drills
Torque limiter quick to engage Why?
Usually it is a worn clutch that will cause this.
May 26, 2014 | Drills
The 14 Position adjustable torque control How to use and what it is used for and how would it help me while working with my drill.
The torque settings on a drill will stop the drill from driving the screw ( or what ever you are tightening ) when it reaches a specific "tightness" . For example; the setting "1" will only tighten a screw a very little bit, while " 14 " will tightten the heck out of it.
Note: once the screw has reached it's specific torque ( or tightness ) the drill motor will continue to turn but it will disengage the driver, making a kind of grinding sound,it's perfectly normal so don't be alarmed.
Dec 29, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a 6337D which has 16 position torque settings. I do not have any torque measurement device. This said, what does each setting represent in terms of a torque value? Thanks for your help.
Good luck finding any actual documentation on this one. The only thing I could think of would be to put a rag in a vise and clamp the drill in the vise after chucking up a bolt. Set the wrench for your desired torque and adjust the clutch on the drill until the wrench indicates the clutch torque value is what you desire...just a thought.
Take care.
Dec 09, 2010 | Makita 6337DWDE Cordless Drill
How do I select torque setting?
the black ring behind the chuck, has numbers on it, turn to desired torque
May 24, 2010 | Dewalt DC750KA Heavy Duty 3/8'' 9.6V...
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
My Craftsman 19.2 drill's adjustable torque clutch want allow drilling in forward gear.
Try with the drill chuck torque setting set to max. If no joy on that one, work tha low/high speed switch several times. If no luck there, you may need to open the drill and check for a loose linkage, or that something has slipped out of place. It's not difficult.
Regards, --W/D--
Jul 17, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
150 people viewed this question
Top kawasaki Drills Experts
jasbo
jasbo
Jim London
Jim London
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
