Question about Casio Cassiopeia E-100 Pocket PC
E -100 Help
I picked up a pair of E-100's at a hamfest cheap and they both do work the only thing is I do not have any way to use active sync yet ( I did find somebody with a cradle and I should have it by the end of the week) Is there any way to load programs through the compact flash card ? The units do see the card and I made a folder on it called my documents and tried to copy some .cab files over. but I can not find it on the e-100 . Both these systems were dead when I received them I had to put a backup battery and charge the main battery to get them to come up . Any help would be great Thanks Matt
    Master:
  • 551 Answers
Casio had a cable that had a serial port on one side and a connector to the E-1XX on the other side. Activesync works through this: I searched on Casio E-100 sync cable serial in Yahoo. It found two hits for a cable under $40. That should allow you to install programs over your serial port. I have persoanlly only used Etronics form the list of two and they did what they said they would do. "Casio Cassiopeia E-Series Serial Cable Mfg Part No: JK580CA UPC Code: 079767693206 Product listed below is: Sort this table by: New from U.S. Distributor Vendor Rating SORT BY: PRICE | VENDOR RATING VENDOR SOURCE IN STOCK SHIPPING COST PRICE VENDOR RATING TheNerds.net DIRECT LINK Direct from Vendor 04/02/04 Yes See Site $31.86 4.5 out of 5 stars Etronics DIRECT LINK Direct from Vendor 04/01/04 Yes $9.14 $38.35 5 out of 5 stars "
Posted on Sep 06, 2005
Where can I get the Off/Low/High/Auto Control Dial for the Russell Hobbs RHSC600.
I would try ebay or amazon. One of them should have the part you are looking for.
Make sure you put your model number in to make sure you get the right one.
Oct 02, 2018 | Cars & Trucks
Where do I find the product key to activate Windows 8?
The product key is included with the media. It will like the sticker in the image below.
Apr 22, 2015 | Computers & Internet
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Won't Sync with the Subwoofer
i can't get mine to pair ... has it paired for you? thx
Jun 06, 2009 | Philips DC912/37 iPod Docking Shelf Bar...
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
I need to know how to activate the bluetooth for the plantronics p590
first thing is look in your man. for the pairing operation....its gonna be a button you hold down on the headphones that makes it discoverable to what ever your pairing it to. then you just tell the other device to look for devices...should sync right up...if it asks for a code it should be in the man. as well...otherwise try the classics...1234, 0000, 9999,and the like...its always for digits
Sep 25, 2008 | Sony CLIE PEG-TJ27 Handheld
New sudden sync problem PDA with laptop.
got start> programs > active sync> open> then connect the usb cable...after phone is detected try to do sync. reinstall active sync can also help.
Oct 02, 2007 | HP iPAQ HX4700 Pocket PC
Netopia 2241 Modem losing sync?
If your modem is losing sync with ADSL 2 that means that your line has a problem. Try having your DSL provider move you to a new Cable and pair.
Sep 11, 2007 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
I can't perform Active-Sync with my Serial Cable to Casio E-100!?
You might try this.... Assuming that you deleted a file you shouldn't have, perform a hard reset on the Casio. You know the type, the type that will erase everything from memory and reset the device to like new. I think you hold down the power button while pushing the reset or something like that if I remember correctly. If you've already reinstalled activesync, they you would be all set.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Casio Cassiopeia E-100 Pocket PC Logo
247 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
