Question about Campbell Hausfeld PL155100AV 7 Inch Pnuematic Sander
What size of Saneder?
What size of sander to use?
    President:
  • 2,712 Answers
F you don't have room in your workshop for a stationary sander, you may want to look at benchtop machines. These sanders offer power and stability, in a smaller size. One bonus is that the benchtop sanders are usually much less expensive than the standing machines.
Posted on Aug 27, 2008
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
Disc won't adhear to pad
I have had this happen twice (I use the sander quitder e a bit.) The sander pad needs to be replaced. Dixieline (Probuilders) stocks them or you can or order it on line at http://www.ereplacementparts.com/makita-bo5010-sander-parts-c-97_103_112.html .
Nov 28, 2010 | Makita BO5010K Random Orbit Sander, 2 Amp,...
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
How do I change the sandpaper in my Black & Decker Sander 7448? I lifted the two levers and the sandpaper came out but now I cannot get them to close tightly around the replacement sandpaper.
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Nov 15, 2009 | Tools & Hardware - Others
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Motor & pulley
It would take 6" pully w/ a 2.25" which would not fit on that machine, no room for the 6". Replace with the same RPM motor is the proper way, unless you simply want a slower speed sander, duh! You cannot change the motor rpm without a defenant power issue, if you change the rpm your sander will power out, sorry?
Mar 30, 2009 | Tools & Hardware - Others
Size of hole in 10inch blade for dewalt power workshop radial arm saw
The size of the hole directlly relates to the size of the blade that fits on the saw, do not change blade sizes it is dangerous and will not fit properly
Mar 10, 2009 | Dewalt Factory-Reconditioned DeWalt DW432R...
Sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Dec 24, 2008 | National Tools & Hardware - Others
Campbell Hausfeld PL155100AV 7 Inch Pnuematic Sander Logo
97 people viewed this question
Top Campbell Hausfeld Tools & Hardware - Others Experts
Are you a Campbell Hausfeld Tool and Hardware - Other Expert? Answer questions, earn points and help others
