Question about Emerson InSinkErator W-152 Point-Of-Use 2-1/2 Gallon Water Heater...
How to Replace Water Heater
I Need to Replace my Water Heater. What is the Most Efficient Type of Water Heater?
    Problem Solver:
  • 14 Answers
Number one cause of a new electric WH not working is failure to remove all the air in the tank before turning on the power. Water heater elements quickly overheat and rupture if not fully immersed in water. After the water is turned back on a new heater should be allowed to fill until water runs out of the temperature and pressure relief valve (located within the top six inches of the WH, and piped down to within six inches of the flow according to most codes). Once water begins flowing out of the relief valve the valve should be closed. Then air should be bled out of all the hot faucets in the home BEFORE YOU EVER TURN ON THE POWER. If that was not done you will have to replace the top element in your new heater, and, of course, this is not covered under warranty, since it is installer error.
Posted on Apr 07, 2009
What makes a heating element go out on a brand new water that i just bought this past weekend. or was it a defected water heater to begin with ?
Posted on Dec 16, 2008
    President:
  • 2,712 Answers
Before you rush out to buy a new one, you'll want to find out which type of water heater is most efficient. Your decision will be heavily predicated upon whether your home is set up to run an electric or a gas water heater. One general piece of advice is valid regardless: Don't assume you need to buy the same size water heater as you currently own. It is possible that you can install a smaller water heater if, in recent years, you have replaced other household appliances, such as dishwashers and washing machines. Newer products often include power and water saving features, and thus, you might be able to buy a smaller water heater that will cost less money and use less energy. Whether your requirements dictate gas or electric, learning which models are most economical is fairly straightforward. Federal regulations require that water heaters display Energy Guide labels. These labels include the Energy Factor (EF) that measures the overall efficiency of a model; the higher the number, the more efficient it is. The labels also will have a First Hour Rating (FHR) that indicates how many gallons of water that model will produce during a peak usage hour. Additionally, you can get energy savings information and rankings on some of the most popular brands of water heaters through consumer organizations and reports. A word about on-demand water heaters: On-demand water heaters, also called tankless water heaters, or spontaneous water heaters, can be fueled by either gas or electricity. This design is much more efficient than standard models. An on-demand water heater is smaller and does not keep a reservoir of heated water on hand for anticipated use. Instead, as soon as you turn on the faucet, the fuel source fires up and the hot water is delivered. This type of water heater requires some refitting during installation in order to provide powered venting and possibly a larger gas line, so it is best to hire a professional to do the job. On-demand water heaters are especially practical for small apartments or single-person households. Larger households will require multiple units. Once you have installed your new, energy efficient water heater there are even more ways to increase its efficiency. Remember to purchase insulation blankets, lower your thermostat, add an overnight shutoff timer, install heat traps, insulate your pipes, and be diligent about regular maintenance. If you take these steps, you can rest assured that you will have the most efficient type of water heater available.
Posted on Aug 27, 2008
Water heater not making hot water
1) Electric water heater can be repaired, no need for new one.
Copy following links:
http://waterheatertimer.org/images/Water-heater-ther-ele-600.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
2) Ordinary homeowner can turn 6-year electric tank into a lifetime tank.
http://waterheatertimer.org/How-to-maintain-water-heater.html
3) If you replace heater, then buy inexpensive tank-type from local box store, and use coupon or offer 10% off. Read the product manual.
Avoid tankless at all costs unless you are rich.
No need to buy expensive water heater on the promise of thicker insulation or higher energy factor, or 'lifetime elements' or 'advanced technology', any other slicker promotion aimed at folks with the promise of a golden rainbow of money-saving-bliss if only you would spend more money. All costs are energy. Expensive water heaters do not pay back, and 1 repair will dissolve all anticipated savings. And expensive heaters can never be maintained to last as long as ordinary tank-type electric.
Feb 17, 2013 | Reliance Water Heaters
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Jan 03, 2013 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
I have a Rheem Model # 62SV-520 and I loose hot water after about 10 minutes in the shower. I think one of the heating elements is bad, but if so, which one.
There performance depends on your demand. If you are using an energy saving shower head I would expect you to have enough hot water for easily a couple of showers. But, if your using the "power flush" type shower heads that use 3.5 gpm or more, the 40 gallon heater is not enough. Also, consider type of water your heating. Is it well water or municipal. Unsoftened well (this includes some municipal well supplies too) water causes hardness ions to cake the heater element making them less efficient. If you have the low flow shower, it is likely you have an element burt out. They can simply be replaced and picked up at any big box store for less than $20 dollars. Each element can be tested in place with a continuity tester. If your not sure how to test, but would be willing to replace the elements - replace both of them. You will have to shut off power to heater and drain tank completely before removing elements. Replace elements with same wattage or higher. Most have two 2250 watt elements for a total of 4500 watts. you can easily install two 3000 watt elements and have a quicker recovery rate and more hot water than ever.
Jan 03, 2011 | Rheem 81VP6S/430126 Water Heater
Not enough hot water,running out before I'm finished showering.
Hot water heaters are a touchy thing. There performance depends on your demand. If you are using an energy saving shower head I would expect you to have enough hot water for easily a couple of showers. But, if your using the "power flush" type shower heads that use 3.5 gpm or more, the 40 gallon heater is not enough. Also, consider type of water your heating. Is it well water or municipal. Unsoftened well (this includes some municipal well supplies too) water causes hardness ions to cake the heater element making them less efficient. If you have the low flow shower, it is likely you have an element burt out. They can simply be replaced and picked up at any big box store for less than $20 dollars. Each element can be tested in place with a continuity tester. If your not sure how to test, but would be willing to replace the elements - replace both of them. You will have to shut off power to heater and drain tank completely before removing elements. Replace elements with same wattage or higher. Most have two 2250 watt elements for a total of 4500 watts. you can easily install two 3000 watt elements and have a quicker recovery rate and more hot water than ever. Good luck.
BW
Nov 27, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have. A vanguard. Energy efficient water heater in a mobil kitchen I don't. Get any hot water
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Aug 27, 2010 | Vanguard International Vanguard 82V66-2T...
Water heater replacement
Direct vent water heater is your best option with gas - may be best to stay with electric - today's electrics are more efficient.
Mar 10, 2009 | Water Heaters
Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Feb 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Is an oil burner efficient for a detached 2 car garage w 1 BR apt
the best oil burner to use would be of the condensing combination type as this would be abt 96%efficient and only heat water as you needed it probably saving you abt 30% on your oil bill
Nov 12, 2008 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Emerson InSinkErator W-152 Point-Of-Use 2-1/2 Gallon Water Heater... Logo
436 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
