Question about Elements of Design DS492 1/2" Inlet Copper Pipe Application, 2 Shut Off Bal
Dryer's vent hose Problem
I think I got a problem with my dryer's vent hose but I don't really know how to check it. Can you help me?
    President:
  • 2,712 Answers
Wait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe. Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals. If your vent pipe is punctured or damaged, you should replace it.
Posted on Aug 27, 2008
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
How to fit vent hose in Philips AWB 650 tumble dryer?
I don't think a vent hose is an option. If you really need one because of condensation, buy a dryer with a condenser unit or change it for one with a hose option.
Aug 29, 2014 | Dryers
Dryer not heating properly
More often When you experience a problem like this with your dryer it is becouse of a clogged dryer vent hose or the vent in the wall. Disconet your dryer vent hose from the dryer to see if it will dry properly. Then you will know if the dryer or the vent.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Maytag Dryers
I HAVE PURCHASED A NEW DRYER HOSE AND CONNECTED IT TO THE DRYER AND OUTSDE VENT, STILL NOT DRYING. I HAVE CLEANED THE OUTSIDE VENT TOO. I DO NOT KNOW WHAT ELSE TO DO, PLEAS HELP...
Is the heating element or gas valve opening to begin the heating process? I don't know what you may have posted before that had you get a new hose , but if you reply to this I will surely assist you in possible remidies for your problem
Jul 06, 2011 | Dryers
I recently purchased a Danby Premiere 13000 btu portable air conditioner. I live in a condo with swing out windows. What are my options for venting (short of returning the unit for a refund or replacing...
John, unfortunately, you don't have many options, short of putting a hole in an exterior wall and putting an exhaust pipe with a cap (like a dryer vent has) and connecting the exhaust hose to it. OR if you have a clothes dryer in your condo and it's vented to the outside. You could temporarily disconnect the dryer's vent hose and connect the A/C's vent hose to the the dryer's outside vent.
Either way, it may be to much of a hassle . But, I'll let you decide that. I guess it will all depend on how hot your condo gets without A/C.
Let me know how it works out for you. Thanks.
May 05, 2011 | Danby Heating & Cooling
My dryer is not heating well I think that the lint compartment is full and it seems to be hot towards the bottom of the dryer. I would like to know ho to get the lint out of the bottom of the dryer.
You need to unplug it and remove the dryer vent pipe from the dryer. You should be able to see lint backed up there, or more likely, the vent hose leading to the outside need to be cleaned out as well. I use a shop vac or a brush on a stick. I have a cob web brush on a telescoping pole that works really good for me.
Sep 08, 2009 | Dryers
E harmony dryer has moisture in the screen and water on the floor
he vent not being hooked up right can be a big problem. The dryer needs to be able to freely exaust all that moist air, and obviously it's not going anywhere. to continue using it like that will eventually kill it - the moisture will keep building up inside until something fries. Something in the vent system may have been damaged during the move, but normally it's pretty hard to damage them.
At this point, before anything else, I think you should not touch anything on the dryer, and run it EMPTY for a cycle or two - this might help dry out your keypad. After that, pull the lint screen out, pull any vent hose out of the back, and reach in as far as you can, checking for lint. You can also use a coat hanger to gently reach down into where the lint screen goes, and see if you pull anything up (unplug the dryer first!). Use a vacum to clean out both ends. If you're really adventurous, you can pull the front cover off the dryer, and take apart the vent system, or at least make sure it's intact - that will require more research, and much more work for you.
Once you are satisfied you have got all the lint out of it you can, run it with a load of clothes and no vent hose, and see how it works. After that, you can check the vent hose for lint also, and get the dryer properly vented. You can also stick the leg from an old pair of nylons on the vent outlet from the back of the dryer, but it should be cleaned VERY regularly.
Sorry for the long answer, but I hope this helps. Please rate if it does :)
Mar 18, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer vent pipe has condensation issues.
With all of that condensation I'd be suprised if your clothes were getting dry at all. A lot of times cleaning the dryer vent is not enough. It sounds like your vent is really long. Long vent lines have a large potential for lint clogging. Check the airflow at the end of the vent at the side of the house. Your'e probably getting very little. For a run like that we always attach a electric leaf blower to the dryer side of the hose and let it run wide open for about 5 minutes. This should help to break up any clogged up lint. You can check your results at the end of the line on the ground. If it doesn't do much you may want to consider replacing the vent hose. Hope this helps.. Thanks
Feb 18, 2009 | Whirlpool Dryers
Dryer lint throughout the house
i think the dryer vent hose on the back is clogged or has come off,check that and let me know-mike
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer gets really hot, but the clothes take a long time to dry and it is really humid inside the dryer. Also, there is a weird smell almost like a burning smell.
It sounds like the dryer isn't getting enough airflow, which might mean a clog.
Make sure you clean the lint filter every time. Also, make sure the vent hose isn't kinked or clogged (if you can, remove the vent hose and clean it out.) Also check between where the vent hose connects to a wall or pipe. There could be a lint clog anywhere between the dryer and where the air leaves the house.
Dec 02, 2008 | Dryers
Elements of Design DS492 1/2" Inlet Copper Pipe Application, 2 Shut Off Bal Logo
181 people viewed this question
Top Elements Of Design Plumbing Experts
Paul Carew
Tom Chichester
Are you an Elements Of Design Plumbing Expert? Answer questions, earn points and help others
