Question about Kohler - Toilet Tissue Holder - Bancroft Accessories - K11414-CP
How to Clean my Toilet?
How should I clean my toilet? Which kind of materials should I use?
    New Friend:
  • 4 Answers
If you want a healthy and hygiene cleaning of your toilet place, you can go for any of the professional cleaners, as they would provide you best high standard cleaning and a range of reliable specialist cleaning & Maintenance services.
You can prefer gutter cleaning Birmingham for this purpose. They offer a cleaning maintenance and repair service to ensure that gutters, drainage and down pipes are regularly checked and cleaned.
They also have specialist cleaners which are accredited and certified by NDCA National Duct Cleaning Academy.
Posted on May 29, 2017
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Growing up the son of a plumber, I would have provided the same answer as Tina. However, Since November, 2014, I'm out with the old way and have been conformed to being more environmentally friendly and with proven results.
How to Clean my Toilet? - clean-toilet-2a0cfbtak4y3luwyen1qnfe3-4-0.jpg I purchase these quality products here:
www.ChristineFrey.Norwex.biz
Thank you for making my cleaning life easier, faster and effective! I now have more time for my children!!!!
Posted on Jan 30, 2015
    President:
  • 2,712 Answers
The water line in the toilet bowl should be lowered, and there are at least 4 different ways to accomplish this. A disinfectant or detergent cleaner or bowl cleaner should be applied to a bowl swab and starting under the rim working down, cleaning the bowl. Disinfectant/detergent cleaner should be applied to the outside surfaces including the handle and allowed to remain wet for ten minutes for a total kill of bacteria, fungus and virus. Flush the toilet, and rinse the outer surfaces. A phosphoric bowl cleaner can be used in toilets with hard water or in extreme hard water conditions where the toilet is not cleaned often a hydrogen chloride based (muratic acid) can be used. Be care of the "kick back fumes" and dripping it on nylon clothing and carpeting. Recommended Materials - # Rubber gloves or vinyl work gloves (type worn to wash dishes) # Eye Protection (usually required in cleaning toilets outside the home) # Disinfectant/detergent/cleaner (any chemical that calls itself a disinfectant and has an E.P.A. number on the label to back-up the claim of being a disinfectant) # Disposable toweling or launderable cloth # Bowl Swab (12-inch long plastic handle with a bunny tail material at the end approximately 4-inches in diameter); Optional Materials - Acid based bowl cleaner depending on the hardness of water and/or frequency of cleaning: # citric acid - safest to use but slowest to remove mineral deposits # phosphoric acid - safer than hydrochloric acid, won´t smoke chrome. (Hydrochloric acid is harsh, use only on porcelain with extreme care and only on the worst mineral build-ups. Note: hydrochloric bowl cleaner will "melt" nylon carpet and nylon hose, so be careful.) # Pumice stick (an alternative to harsh bowl cleaners for removing mineral stains and deposits)
Posted on Aug 27, 2008
Toilet bowl will not drain when flushed
if your flapper is held open and the toilet rises to the rim and does not flush then you need a closet auger and clean out the toilet as it has debris restricting the flush
Mar 02, 2014 | Plumb Craft Perfect Flush Toilet Kit
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
Leak from the toilet every time it is flushed. It is a new toilet, flange, extender, and wax ring all installed 1 year ago.
Lift your toilet off again and replace the wax ring check the bottom of the toilet for cracks and make sure it is clean. Then install the toilet make sure to tighten flange bolts evenly DON'T OVER TIGHTEN. Try that to start with.
Feb 02, 2013 | Home
How to clean dirty toilet
Try a pumice stone they work great & can make a toilet bowl look brand new, there with the cleaning supplies in any store.
D :)
Feb 01, 2013 | Kohler Home
Flapper leaks
this is a case that dictates you replace the flapper.
Mar 06, 2011 | Eljer 141-0220-00 Toilet Tank White
The toilet seat looks terrible on the underside and on the top it has the worn look. The price of over $400.00 to replace it is crazy. Is there a way of painting , cleaning up or should I buy a a new...
You should be able to remove an old worn out, toilet seat and replace. Usually its two Plastic Toilet Seat Bolts and two plastic wing nuts under the bowl. Most of them are hidden in a Plastic Cap where the seat attaches to the Toilet Base. You unsnap the caps to see the bolts. Make sure to hold the Wing Nuts underneath or they might just spin.
If its a matter of cleaning something because of neglect. I have recently started using new products that I purchased from www.ChristineFrey.Norwex.biz with great success!
I clean the entire bath room with three products and water!toilet-seat-looks-terrible-underside-2a0cfbtak4y3luwyen1qnfe3-5-0.jpg
Dirty to Clean its simple fast and effective.
The products are: my EnviroCloth, Blue Diamond Cleaner and my toilet brush. If you are like me, I never heard of any of this until I saw a demonstration November 2014 by this person who's website I posted above in this response.
Feb 28, 2011 | Herbeau Charleston, White Toilet Seat &...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
I have a 3 bath rental. The last tenants were
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
Oct 24, 2009 | American Standard 2860.334 Enfield Two...
Kohler - Toilet Tissue Holder - Bancroft Accessories - K11414-CP Logo
824 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
