Question about Hansgrohe E & S Accessories 40526000 Polished Chrome Toilet Paper Holder
How to Install Toilet Paper Holder?
How do I install a toilet paper holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
Posted on Jan 31, 2009
    President:
  • 2,712 Answers
Decide where you want the toilet paper holder to be. Obviously, it should be in a spot that's easily accessible and close to the toilet. Determine whether or not there is a stud where you want to install the holder. Ideally, you want to have at least 1 screw in a stud. However, if that isn't possible, use some type of hollow wall fastener to attach the holder to the wall. Hollow wall fasteners grip the wall when you put them in, so they're great to use when you can't count on a stud as an anchor. Place the toilet paper holder where you want it and use a pencil to mark where to put the screws or hollow wall fasteners. Use a tape measure if you need to center the holder. It's also helpful to check your marks with a level to ensure the holder will be straight once it's installed. Drill appropriately sized holes for the holder's screws or the hollow wall fasteners. Install the hollow wall fasteners, if needed. Screw the toilet paper holder to the wall or the fasteners. Make sure the holder is tightened securely, but don't turn the screws so tight that you strip them out.
Posted on Aug 27, 2008
Tighten grohe toilet paper holder
Hi!you will remove the flanges in your toilet paper holder there you will see the screw and you will tighten it by screwing it.
Sep 03, 2011 | Home
How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
The technical specifications and installation instruction for your product are available here.
http://www.moen.ca/shared/pdf/yb2208sp.pdf
At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
Nov 15, 2010 | Moen YB2208CH Brantford Toilet Paper...
PRPH toilet paper holder. the fixture attached to the cabinet and supports the toilet paper holder has a broken post. The post goes into the toilet paper holder and supports it. During remodeling, I...
Without more specific information or a product number difficult to assit; here is the website for the manufacturer where you can search for more information or find a parts supplier near you.
http://www.robern.com/info/documentation.rbn
Trust this is helpful.
Oct 26, 2010 | Robern Prph Projects Toilet Paper Holder...
HOw do I remove the moen toilet paper holder from the wall
Without looking it up, I can figure it has a tiny screw on the flange bottom, and when it is loosened, it will come off, then the holder, keeper, is screwed to the wall. If it is not held on by a little screw, setscrew, then try turning the whole thing off, it might be threaded. Hope this helps.
Jun 11, 2010 | Moen DN0708CH Iso Pivoting Toilet Tissue...
How to remove the mounting flange from a circular, one-arm toilet paper holder, so it can be re-mounted? there is no set screw to release it-- the flange has two screw holes on either side of a center...
you will need a vary small flat screw drive and at the bottom of the holder the is a small hole insert screw driver and un screw, it has a small screw that holds to the plate on the wall
May 05, 2009 | YORKSHIRE 5308 - Yorkshire Paper Holder -...
Toilet Paper Holder
if it's the kind that is inset you unscrew it if it's the 2 post's attached to the wall look under 2 screw's
Mar 27, 2009 | Home
Hansgrohe E & S Accessories 40526000 Polished Chrome Toilet Paper Holder Logo
1,870 people viewed this question
Top Hansgrohe Home Experts
Shehu Pro
Shehu Pro
 John
John
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
