Question about West Brass WestBrass Faucet Master Contemporary Flat Rain Shower Head with 6" Diamete
Vent Pipe Installation
How many bends can I put in the vent pipe?
    President:
  • 2,712 Answers
More than 3 90° bends will disrupt airflow. We also do not recommend any horizontal lengths (no matter how short) or downward dips of the pipe. Fasten your pipe to the structure with the supplied brackets to prevent settling.
Posted on Aug 27, 2008
Slow fueling 2007 fleetwood terra motorhome very slow
Have a look up under where filler pipe/hose is attached from opening to tank and look for a sharp bend in either fill pipe, or vent pipe (smaller) Not uncommon for vent hose to get a sharp bend in it.
Feb 19, 2015 | Fleetwood 2008 Terra LX 31M
I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
I boughta vermont castings model # 2610 cast iron radiance franklin stove it came w/pipes .............is it a direct vent or a b vent..reason why i am asking is he gave me a "t" pipe w/ screen...
It the opening on the stove is on top of the stove, it's a 'B' vent. If the opening is in the back of the stove it's a "Direct Vent". However, some models have a connection on the back that's facing up,. A 90 degree elbow can be used to convert it to a horizontal run to enter an existing chimney, but then it must elbow up to connect to the pipe that is required to line the chimney. You should not just stop the pipe above the damper. It needs to run all the way to the top of the chimney, then have flashing seal the chimney's clay liner and a termination cap on the top.
here is a link to the Owners Manual/Installation Instructions for a Model 2600. It installs the same way as the 2610. http://homeappliance.manualsonline.com/mdownloads/62b85343-a800-4898-85a1-3d6d3c524259.pdf
Hope this helps you sort things out and do a proper installation.
Apr 18, 2011 | Heating & Cooling
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My reliance sta-kleen 502 is leaking. The water is dripping on top of the pilot light, extinguishing the flame . Please advise me with step by step instructions to diagnose and attempt fix this myself....
If you have a leaking water heater there is a serious problem.
http://waterheatertimer.org/Water-heater-leaking.html
Page shows how to limp along on a leaking water heater if your water heater needs replacement.
One of three things is causing the water:
1) Loose water connection on top of tank that is dripping down inside tank >> check pipes on top of tank.
2) The vent is clogged or not working correctly causing condensation inside flue pipe.
Condensation water is dripping back down inside tank.
Problem means possible CO poisoning if gas is not venting.
Look at vent pipe to see if joints are corroded.
Use long fireplace match > light match and put into draft hood at top of tank and see if smoke goes up.
Put hand at draft hood opening when water heater turns on to see if vent gas enters home.
Do same test when furnace turns on to see if furnace vent is pushing back into water heater.
Does water heater vent inside same pipe as furnace? You may need to set up separate vent for water heater if furnace gasses are pushing back into home.
Check furnace vent for obstructions.
Look at vent stack top of home to see if hood is in place.
Check if bird nest is built inside warm vent pipe.
Improper flue is top priority for getting fixed so vent gasses properly escape home.
You may have to call a plumber.
Professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Your water heater is rusted out.
A rusted tank has to be replaced.
It cannot be repaired.
However, before replacing tank, you do not want a tank failure where tank ruptures and water runs inside home until water is shut off.
This will cause major damage.
Protect yourself first.
Turn off water valve above tank.
Move gas knob to 'pilot' so burner is not heating water.
Open tub spout on hot side to relieve pressure on tank so it will not rupture.
Now you're protected.
Link above shows how to limp along on failed tank until you can replace heater.
You need a new gas water heater from Lowes or Home Depot
Look at label on side of you tank for gallons and btu's of your water heater.
Measure height to flue pipe so you get same height water heater, so pipes don't have to be changed.
You need a pipe wrench and teflon tape which will be wrapped on each pipe thread when pipes are reassembled.
Step1) Drain water heater using valve at bottom of tank.
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Turn off gas valve going into heater.
When gas valve is perpendicular to gas line, then gas is off.
Dissemble gas line to water heater.
3) Disconnect flue pipe and support flue pipe with wire so it doesn't not fall down. Flue pipe joints should be held together at each joint with 3 screws.
4) Turn off water. Shut off valve is on COLD side.
Disconnect water pipes.
5) Move old water heater out of way.
6) Set new water heater in place. Put water heater in drip pan.
7) Connect water pipes >> cold goes to side marked cold.
Hot to hot.
Buy new flexible water connector pipes at home center for easy installation of water pipes.
8) Connect gas line exactly as it was connected before.
Home center sells flexible gas line connector for easy installation of gas line.
To test for gas leak after installation, mix liquid soap with water and put around gas line joints to see if there are bubbles.
Natural gas has less pressure than water lines, so gas pipes are easy to seal with ordinary wrench.
9) install TP pipe that runs to floor. Use old one off old heater.
10) Fill tank completely with water until water is coming out of tub spout.
11) Turn on gas, and light pilot as shown in manual.
New gas heater sometimes have small water leak when first fired up, so ignore a bit of water.
12) Save water heater manual like it is gold, and read everything in manual.
Dec 18, 2010 | Water Heaters
It is not drying very well even on the very dry setting, why?
This may sound silly, but have you cleaned the dryer vent pipe from the dryer to the outside of your house? If that vent pipe is plugged, or partially plugged, your dryer will not dry properly. When I have had this problem in the past, the first thing I do is take the dryer out of the house and blow it out with a leaf blower. I put the leaf blower nozzle in the vent trap area, pack a towel around the blower nozzle, turn it on high and watch the lint fly. This ensure the dryer is cleaned out of any excess lint. Next, I take my leaf blower into the house, put the nozzle in the vent pipe (packing a towel around it also) and turn it on high and blow all the lint out of vent. I would caution you to check your piping the make sure all the vent pipe sections are secure. (The first time I blew out my vent pipe I had lint all over my basement due to poor connections in the tin piping. I promptly took aluminized duct tape and covered all of the seams.) My dryer always drys so much better after doing this simple procedure.
Feb 19, 2010 | Bosch Dryers
The pipe dosent seem to be letting out the steam and its going to the bottom of the tumble dryer
You most likey have a plugged vent ppe or the pipe is to long or have two many bends in it. try laying the vent pipe out and see if you can see anything in the pipe. Next if the pipe is clear check outthe vent door and make sure it is not plugged or the door is not frozen shut.
Oct 02, 2009 | Bosch WTE86300 Electric Dryer
I have a whirlpool front loader and need to run a vent. Does it need to be a hard pipe or can it be the metal type flex pipe?
Hi.
It does not really matter which type of vent you use, so long as it is the correct diameter, and try to run it without any bends if poss, as too many bends will restrict air flow.
Please rate my solution.
Thanks.
Jun 17, 2009 | Maytag Dryers
Size of vent pipe
You will be fine with 2 bends in an 8 inch pipe. If you bend it more than 3 times though you will loose fan force. If you up to a 10 inch duct you will not have good fan force because the space is bigger.
Good Luck and Please Rate FixYa!
Feb 25, 2009 | Fantech Fan FG8XL
Fuelin up my ford escape
In left rear wheel well under a plastic cover is your fill and vent pipe
A coupling from plastic pipe to metal pipe must be taken apart and air blown into tank
This plastic line is bent down and collects overfill and moisture, thus not allowing tank to to vent as you fill.
Once you have cleared plastic line and reassembled coupling , gently bend metal pipe so plastic line drains towards tank.
Manufactures fopa
Oct 26, 2008 | 2005 Ford Escape
West Brass WestBrass Faucet Master Contemporary Flat Rain Shower Head with 6" Diamete Logo
860 people viewed this question
Top West Brass Plumbing Experts
Paul Carew
Tom Chichester
Are you a West Brass Plumbing Expert? Answer questions, earn points and help others
