Question about Kohler Model 7193: Drain For Sok® Overflowing Bath - Vibrant Brushed Nick
Blockage Repair What equipment do I need to clear a blockage in a private sewer?
    President:
  • 2,712 Answers
If a blockage does occur, then having something to hand to deal with it may save you time, money and inconvenience. A medium-sized hand plunger should cope with most blocked sinks. You should also have a spanner of the correct size to remove the trap underneath the sink. A set of drain rods should be sufficient to clear most blocked private sewers. If a blocked private sewer cannot be cleared by your use of the drain rods, then you will probably need the services of a sewer cleansing specialist.
Posted on Aug 27, 2008
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
How to clear a blockage
probably heater element in freeze to let water drain if no element clear hose out
May 01, 2014 | Dometic RM2652 Refrigerator
Toilet not filling fully and smell of sewer
This is usually caused by a partial blockage inside the toilet. Try using a plunger to clear it, if that doesn't work, get a toilet auger from your local home improvement store
Jan 28, 2014 | Kohler Cimarron 2-PC Elongated Toilet with...
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
Replaced the drain hose and now during washing water tends to back up while draning out the sewer pipe.
New hose end may be aimed into drain pipe side causing water to gush back and not straight down drain. Some hose holders are difficult to align. If old hose was restricted and new one is not, the volume of the washer pump can back up a restricted drain. Clear blockage or reduce hose output and live with it. Washer pump out time should be adequate.
May 30, 2011 | Kenmore Elite 45986 Front Load Washer
I can't use the facebook website. it is always page error.
Hi there, seems there is some blockage issue in your network or from ISP. Try using Proxy or VPN(Virtual private Network) connection.
Also this can be cause of cookie storage. Try clearing cookies from your internet cache. Please try these and let us know the result.
Thanks for joining Fixya.
Good Luck
Sep 12, 2010 | Facebook Computers & Internet
Sewer gas smell
blocked drain outside you will need to get somone in to flush it out and the problem will be solved
Dec 31, 2009 | Saniflo Sanibest Grinder Pump Only 013
Kohler Model 7193: Drain For Sok® Overflowing Bath - Vibrant Brushed Nick Logo
537 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
