Question about Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br
Toilet seat covers protection
Do toilet seat covers provide any real protection?
    President:
  • 2,712 Answers
Nope, but your seat doesn't really need protecting. All those paper covers do is mentally separate your backside from the countless bums that have occupied the same space.
Posted on Aug 27, 2008
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
NEED TO REPLACE THE SEAT AND COVER OF THE TOSCA TOILET
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=365570&chnl=cse&ven=googlebase&cat=Bathroom%3AToilet%20Seats&brnd=Herbeau&itm=0651'Herbeau%200651%20Monarque%20Toilet%20Seat%20and%20Cover%20Only%20in%20Plain%20White%20-%200651
The picture shown with your post shows a toilet seat that looks like the one sold at site above.
But the site above is selling the toilet seat called the Monarque toilet seat and cover.
The particular seat shown is not called a Tosca.
Another site shows the identical whole toilet, and calls it the Herbeau
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
The pdf from Eljer showing the Tosca toilet looks very similar to both the products shown on the two links above. Maybe this solves the question.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 05, 2010 | Eljer Toilet Seat Tosca 124200000
New toilet was installed in my apartment and I don't like the seat. Do you have different seats available? maybe a seat cover?
you can change out the seats any oval should fit an oval toilet and a round will fit a round toilet
just go to your homedepot, lowes, ace, etc. and pick out the 1 you want.
Nov 15, 2010 | Villeroy & Boch 9957 S1 Aveo Toilet Seat &...
Can't find replacement seat for the toilet? Where
You can't be serious? Get yourself down to Loews, Home Depot or Menards and get yourself a seat brother! It's not rocket science or that only Jacuzzi seats fit fit Jacuzzi toilets lets get real, comon lets get er done PAL.
Jul 26, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Aug 27, 2008 | Hansgrohe E & S Accessories 40522000...
How to Improve Sanitary Conditions
You should use toilet seat paper covers. In addition to promoting sanitary conditions, the use of disposable toilet seat covers can also help your organization to save both time and money. When you consider the alternatives of toilet seats, it is easy to see how beneficial toilet seat covers can be. When visitors to your restrooms use the proper toilet seat covers, restrooms are more easily maintained.
Aug 27, 2008 | Kohler Flush Actuator K 9446 [ Bathroom,...
Toilet Seat Cover Question
Toilet seat covers is the solution for a more comfortable sitting while using the toilets. Also, it protects you from sitting on other people's urine
Aug 27, 2008 | Kohler Santa Rosa K-3323-55 Innocent Blush...
Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Logo
148 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
