Question about Scotts Company Scotts& Accugreeen 3000 Drop Spreader 3 Pack
How to use Spreaders
How to use the spreader most efficiently?
    President:
  • 2,712 Answers
Follow the specific spreading instructions that come with your spreader. When working with spreaders, always load a spreader on a surface where an accidental spill can be cleaned up and won't matter (driveway, walkway, etc). Common practice is to first run the spreader around the periphery of the area you are treating; this ensures a consistent application around the edge of your lawn. Next, you run the spreader back and forth within the area bounded by your first perimeter run. Always allow on overlap to avoid missed streaks or "holidays". Ideally, apply your material at half the recommended rate and make two sets of runs, first back and forth in one direction, then again another set of runs at 90 degrees to the first set. This ensures a good consistent coverage and it compensates for any uneven patches.
Posted on Aug 27, 2008
What causes the fertilizer to stick in the holes of the drop spreader and not go on the lawn?
Posted on Aug 11, 2009
I need to find a manual on my new SCOTTS LAWNS #73730 Drop Spreader 3000 did not come with instructions on using the dial
Posted on Sep 07, 2008
  • 2712 Answers
SOURCE: Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
  • 2712 Answers
SOURCE: Spreaders Guidelines
It is always a good idea to calibrate your own spreader, even if the manufacturer provides guidelines for setting the spreader with different products. It's easy to calibrate and, if you make a note of your results, you only have to do it once for each product.
  • 2712 Answers
SOURCE: Spreaders how does it work?
An axle or “beater bar” is located inside the bin next to an open slot in the floor. Attached to the axle is a series of beater arms or paddles. When the axle turns, the paddles break up the material and direct it toward the opening where it is deposited evenly on the soil.
  • 8 Answers
SOURCE: As the cyclone brand spreader is
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Posted on May 01, 2010
  • 25 Answers
SOURCE: IS there a place that lists spreader settings for
If the product you are planning on applying has a spreader setting for a Scotts AccuGreen, or  specifically for the AccuGreen 3000; you can use that recommendation in your Turf Builder Classic Drop Spreader.  If they do not have a suggested spreader setting for the Accugreen, or  Accugreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Posted on Feb 23, 2011
Butter Spreaders
contact customer support
Mar 24, 2014 | Computers & Internet
I need a replacement part for Scotts 73730 AccuGreen 3000 Deluxe Drop Spreader... the plastic part that holds the cable and threads into the dispensing lever.
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 877-465-5160 at your earliest convenience to check part availability. Hilary @Scotts
Aug 15, 2011 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
Where can I get a wheel assembly?
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 1-800-543-8873 at your earliest convenience to check part availability. Hilary @Scotts
Aug 05, 2011 | Scotts 74434 "deluxe" Edge Guard Spreader
Spreader propeller doesnt turn when i push it
I would think it is either it is stripped or loose gears or the roll pin which holds the impeller to the rod is missing. those things happen on the industrial spreaders I use at work.
Sep 17, 2010 | Scotts Company Scotts& Accugreeen 2000...
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
Where can i buy a new spinner plate for my agri fab 175lb spreader
need to know part # agri fab website lists 5 models for dry 175 lb spreaders. see site for manuals:
http://www.agri-fab.com/manuals.aspx#45-0288
scroll down to 45-0288 and see for yourself
Dec 05, 2009 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
Aug 27, 2008 | Agri-Fab Agri - Fab Ground Drive Drop...
Aug 27, 2008 | Agri-Fab Agri Fab Spreader
Scotts Company Scotts& Accugreeen 3000 Drop Spreader  3 Pack Logo
1,884 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
