Question about Whirlpool Safety Bath Walk In Bathtub - Stretch Without
Water pump troubleshooting
How to Tell if a Car's Water Pump Needs Replacement?
    President:
  • 2,712 Answers
Turn the engine off and open the hood. Locate the water pump pulley. The pulley is the round part that the belt is attached to. To find it, look for the belts. You will see more than one pulley. Your car will have an alternator with a pulley and perhaps an air conditioner, power steering and smog pump pulleys. If you are unsure, ask your mechanic to point out the water pump pulley. Grab opposite ends of the round pulley and check for "play" (looseness): Try to rock it back and forth. There should be no give. If there is, the bearings are going and it's time to replace the water pump. By the time you can feel play in the water pump pulley, you may also be able to hear the bad bearing when the engine is running - there may be a low-pitched grinding noise coming from the water pump pulley. Visually check the water pump (it's located behind the pulley) for signs of a coolant leak. If the water pump gasket is leaking, it must be replaced. This is a good time to get a new water pump, too, unless it was just recently replaced.
Posted on Aug 27, 2008
Need to replace water pump on nissan 1997 quest
Not sure why all other parts removed? Locate the water pump by following the lower radiator hose to the motor...the connection is part of the water pump housing...Also look at the replacement water pump to see what few bolts need to be removed to switch the pump. Be sure to use a water pump gasket sealer when applying the new water pump gasket...coat both sides as this also helps to hold in place while re-assembling. Reconnect all hoses and clamps...install the belt before testing...Talk with your local parts store also...the water pump usually comes with a replacement diagrahm too. Hope this helps.
Jan 21, 2013 | 1997 Nissan Quest
Is it safe to drive your car if your water pump needs to be replaced
No its not.The engine will get hot,then overheated and at last damaged.
So its advisable to replace water pump.
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
Feb 15, 2012 | 2004 Dodge Stratus
Water pump crossover housing gasket
Feb 10, 2012 | 2000 Cadillac DeVille
Water pump replacement
Jan 29, 2012 | 1994 Honda Civic
Trailblazer won't start after water pump relacement
Many a times the problem occurs due to timing not adjusted,in many cases the timing belt also needs to be replaced while water pump replacing.
Or its also possible that water pump not replaced properly or timing got mistimed.
I suggest you to check few help links.-----------
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
Jan 26, 2012 | 2004 Chevrolet Blazer
I have a 98 bmw 740il that keeps overheating. I have replaced the water pump about 6 months ago. I have removed the over flow tank and check for cracks. It is in good condition. I also have no heat. The...
I am not aying that this is what I think it is but I found this on your year BMW
Some BMW, Volkswagen and Audi cars have a common problem that the water pump impeller becomes dislodged from the input shaft of the water pump leaving the water pump looking ok from the outside, but failed on the inside. If your car experiences this problem it will over heat rapidly much like a thermostat failure. For exact specific repair procedures for this repair visit our online repair manual page.
Failed BMW, VW, Audi Water Pump Troubleshooting Procedure
  • Check Water Pump Operation - To troubleshoot this problem first drain about a half a gallon out of the cooling system, next remove the thermostat from the engine. With the thermostat out start the engine (stand back) coolant should be forced out of the thermostat port, if not the impeller has dislodged itself from the water pump input shaft and needs to be replaced. To replace the water pump finish draining the remainder of engine coolant, remove the serpentine belt and coolant hoses. Next remove the water pump mounting bolts and remove the water pump. Clean gasket surfaces and reinstall new water pump and reassemble. Refill with coolant and recheck system, top off engine coolant after it has re-cooled.
Nov 23, 2010 | 1998 BMW 7 Series
How to tell if water pump for 04 cadillac srx needs to be replaced.
Your car will overheat very fast and you may either notice coolant leaking from the location of the pump and also possibly a squealing noise due to a bad bearing. Overheating can also be caused by a bad thermostat.
Feb 17, 2010 | 2004 Cadillac SRX
Hayward pump wont prime. air bubbles coming back into pol with water and de
You have a leak, if DE is getting back in pool your filter is either dirty and needs to be taken apart and throughly cleaned, or you have a ripe in one of the DE cells. The pump not priming is a leak somewhere before where water enters pump. Could be a bad o-ring in a valve. Hard to tell what is is without troubleshooting, piece by piece. I would start with cleaning Filter first.
Jun 17, 2009 | Hayward EC-40 DE Pool Filter with pump
Water pump needs replacement
Depends on which engine if it's the 2,2 engine fairly easy but the 2.4 is a big job Timing Cover & Exhaust Manifold Removal Required. With the 2.2 locate water pump loosen the bolts on the pulley then remove the serpentine belt. Finish removing the pulley bolts now you can get at the water pump bolts. Use a container under the car to catch the antifreeze. Remove the water pump from the engine, installing new pump in reverse order to removal.
May 18, 2009 | 1997 Chevrolet Cavalier
Whirlpool Safety Bath Walk In Bathtub - Stretch Without Logo
848 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
