Question about Whirlpool Safety Bath Walk In Bathtub - Stretch Without
Difference between acrylic and fiberglass
What is the difference between acrylic and fiberglass, cast iron, steel, synthetic (like limestone) tubs?
    President:
  • 2,712 Answers
Acrylic is a solid sheet material that is heated and vacuum formed to the desired shape. It is then reinforced at the back with fiberglass to give it strength. It is a higher-end material, very durable and super easy to clean. Fiberglass is a material that adheres to a mold and then a gelcoat finish is sprayed onto it. The most common material used in tubs and showers and is the most economical. Cast iron tubs are forged and the finish is applied in powder form while the tub is hot causing the finish to melt onto the cast iron. Synthetic tubs are molded and then a gelcoat finish is applied like the fiberglass tubs.
Posted on Aug 27, 2008
Removing stain from fiberglass shower base
Even caked-on iron and rust stains can be removed with a little effort. Apply your chosen cleaners to fiberglass tubs using a soft sponge, a nylon, polyester or polyethylene brush with soft bristles, or a soft cloth. Do not use abrasive cleansers, steel wool, abrasive scrubbers or scrapers on the fiberglass tub or shower surround, as these can scratch the fiberglass--in a gallon bucket: 2 tablespoons of white vinegar, 1/2 cup warm water, 1 2/3 cups of baking soda and 1/2 cup of a liquid degreasing dish detergent. Apply the solution directly to the stain and let it sit for an hour before rinsing and wiping clean.
A vinegar-and-baking soda paste applied to stained areas creates a chemical reaction that can remove the stain through the fizzing action generated by mixing backing soda with vinegar. Apply the vinegar and baking soda paste directly to the stained area and let sit for 15 to 20 minutes before rinsing and removal.
Nov 05, 2017 | Home
Tip
Cast Acrylic
Acrylic is a crystal clear thermoplastic material possessing excellent mechanical and chemical properties. Outstanding optical qualities and resistance to both sunlight and outdoor weathering make acrylic an ideal glazing material. Acrylic can be easily cemented, making it an extremely versatile material. Cast transparent acrylic sheet has many advantages, such as excellent transparency, light weight and good flexibility, superior weather resistance, good chemical resistance ,good impact strength as well as easy to drill, cut and polish.
on Oct 30, 2015 | Miscellaneous
What Kind of Steel Shot Is Used In Shot Blasting Machine?
Steel Shot Blasting
Usually, the hardness of steel shot can be improved to HRC40 ~ 62. It can be used in processing hard metal. It is more widely applied in shot blasting machine because of its excellent toughness and long service life.
Cast Iron Shot Blasting
The hardness of cast iron shot is HRC58-70. Cast iron shot is too brittle to be broken easily, so the service life is short. It is mainly applied in those processing of high shot peening strength requirements.
Glass Bead Peening
The hardness of glass bead is less than the previous two steel shot, which is mainly used in processing stainless steel, titanium, aluminum, magnesium, and other situation excluding iron pollution. Also, glass bead can be used in secondary surface treatment after steel shot blasting in the purpose of removing the iron pollution and reducing the roughness of workpiece surface. http://www.jxabrasives.com/
Jan 13, 2017 | Coffee Makers & Espresso Machines
Spa bulges in one area what cause this and can it be fixed
Is this a Fiberglass or Acrylic Spa?
Or are you referring to a portable toy spa that is inflatable?
If the former, your shell surface is delaminating, from the rigid FiberGlass that was sprayed onto the acrylic or fiberglass shell to ridgidize it. What usually happens is "Air" is not completely removed during that spray process and over time, the acrylic will bubble due to the heat in the spa as the air expands. That Acrylic is barely paper thin when stretched out into the mold you sit in. An 8x8 sheet of acrylic is only 1/4" thick, then it is heated and placed over a tub "Mold" and then Vacuumed into what is your tubs shape that you enter into. You can imagine how thin it gets. When it goes through the ridgidizing process, All of the Air needs to be removed, sometimes it is not, and over the years it becomes evident that it wasn't.
What can you do? Well, besides that it is not very pleasing to look at, there is no problem or danger of any leaks, not yet anyway? You can break the bubbles out and find a supplier that sells acrylic repair kits in the color of your spa. You can google with the proper search terms & eventually find a kit. Maybe something like the link below shows...
Large Granite Spa Hot Tub Acrylic Repair Kit
If the latter, Sorry I don't know....
Good Luck
Apr 14, 2015 | Pool & Spa
How do i fox a deep scrape on my fiberglass tub?
A deep scratch on an acrylic bathtub can only be fixed with an acrylic repair kit or call a repairman that can repair the acrylic.
This is a very tricky process and should only be attempted by a qualified repair person.
Rod
US Parts Center
Apr 09, 2014 | Home
I have these 4 buttons on the side of my tub. What do they represent?
north,south,east,west....just kidding! you'll have to clarify if it's a jaccuzzi ,cast iron or steel tub
Mar 13, 2010 | Neptune Home
Cast-iorn tub to fiberglass shower kit not sealing
keep caulking or change to ceramic tile, or one piece shower units ,without seams
Mar 03, 2010 | Home
Is an acrylic sink durable and stainproof?
Acrylic sinks can stain too. I would go with a cast iron sink if you don't want to worry about stains. Acrylic sinks tend to scratch if your not careful.
Mar 13, 2009 | International Thermocast Corp Thermocast...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Welding bearing girdle for Hobart A200?
yes the cast can be welded(brazed). if you are able to weld this yourself, just remember before you can weld it, you have to heat it till it is cherry red then you can weld the piece. if your not qualified to weld it you can usually find a portable welding company to do this for you. hope this helps you please rate the solution...thanks
Sep 18, 2008 | Hobart A200 Stand Mixer
Whirlpool Safety Bath Walk In Bathtub - Stretch Without Logo
1,387 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
