Question about Grizzly G0641 Double Cut-Off Miter Saw
Cut off safety question
Any safety tips?
    President:
  • 2,712 Answers
* Be aware of the location of any power cords when operating a saw, keeping them behind the path of the cut at all times. * Be aware of where cut off pieces of lumber will fall, to avoid injuries. * Most the saws in this category are designed for right handed use. That is, when you are sawing in the normal position, the blade guard is between your face and the saw blade. If you are a left hander be aware that any chips of sawdust, etc. are flying out on your side. Don't forget your safety gear. * Safety glasses or goggles are OK but a full face visor is better. * Don't use dangerous power tools when there's nobody else there with you. They don't have to be right there next to you, just somewhere in the area. You want to make sure that, in case that you injure yourself, there is someone there who can call 911 for you.
Posted on Aug 27, 2008
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
How do you remove the chuck from a dewalt dc720 if the screw is striped inside?
The only way to get it off now is with a grinder and metal cutting wheel. Lock the drill body in a vice with the chuck out of the vice jaws. Wear safety goggles and do not stand or let anyone else stand in the plane of the cutting wheel while cutting, you will have lots of sparks and if the wheel breaks peices will stick into things. You have to make a judgement call but you want to cut just at the head of the stripped screw. It's a lot of steel to get there so be patient and work carefully to remove the tip of the chuck. Once the tip is cut off you may be able to grab what's left of the chuck with a vice grip or lock it in the vice and turn it off the drill. If not, you'll have to make a cut length wise in the chuck so you can split the base and remove it. Be careful not to go deep enough to cut into the anvil or back far enough to cut into the drill body and trans. After making the cut put a chisel in the cut and hit it, hard, until the chuck body splits.
Feb 21, 2012 | Dewalt Drills
Trying to find were the safety fuel cut off switch is located on a 1987 grand wagoner
I have the 87 cherokee and I don't think it has the "tip over" fuel cut off safety switch. If you are not getting any fuel the fuel pump (its in the fuel tank) has either lost power or stopped working. They used a couple of different styles so don't buy one untill you have pulled the old one out. also you can check for voltage on the wires that feed the fuel pump. If you have voltage but are not getting any gas flow then the pump is not working.
Apr 21, 2011 | 1987 Jeep Cherokee
The power adapter cord has a minor cut in it, and the tv will turn on and off, the red light disappears what is the problem?
hi there, good thing you detect it earlier. Heres my tips cut that wire and try to solder it. Or if soldering is not possible rewire it by tie it together and coat with electrical tape for safety. It is possible that you have a cold contact on the supply. Hope this helps. Please rate and vote. Good day
Mar 17, 2011 | Akai LCT2060 Television
Shuts on on safety ,,almost immediatley
Check that the tip is assembled correctly.If is not in properly, it will not arc. Second, check air pressure switch. Sometimes they become stuck from corrosion due to moisture in the air. Test the operation with a tester
Nov 01, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
My husqvana lawn tractor starts well and the engine runs but when I release the brake or apply the cutter it cuts out. Why?
Most likely the seat safety switch or associated wiring is the problem. It's designed to cut the engine if you release the brake or engage the blades unless it detects your weight in the seat. Tip up the seat and make sure the safety switch under it has not come loose, and that the wire connections are on tight. If that all looks OK, take the switch off and put a piece of tape over it the plunger to keep it in the 'activated' position and see if the mower works that way. If that fixed it, you should replace the safety switch. They are just a few dollars. Hope this helps - if so, please rate my answer.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Safety light
check the gun lead all the way back to unit,if there is a nic or cut in that lead (main power lead)the unit will not fire,sadly you cannot fix the lead ,it has to be replace with new one,
Jun 06, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Nov 26, 2008 | Lincoln Pro Cut 55
Safety Problem
Always protect your eyes - wear only an approved eye or face shield
Aug 27, 2008 | Dewalt DW824 5" Electric Angle Grinder
Grizzly G0641 Double Cut-Off Miter Saw Logo
246 people viewed this question
Top Grizzly Saws Experts
Tom Chichester
ray gallant
Are you a Grizzly Saw Expert? Answer questions, earn points and help others
