Question about Whirlpool Pearl Ballade True Bathtub with Back Massage - 100463-100
Difference tubs and air baths
What is the difference between a whirlpool tub and an air bath?
    President:
  • 2,712 Answers
Whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Posted on Aug 27, 2008
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
Where do i get parts for ez bath
If you can blow into the tubing and start the motor then you need to replace the air button on the tub.
Rod
US Parts Center
888-521-6183
Apr 22, 2013 | Ez Access Inflatable Bath Tub Ez Bathe...
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
2748.328 Town Square 5' x 42" Air Bath Tub Won't Work
Air bath tubs have a preset time limit. it could be that it reached that limit. Especially if the lights are still lit up on the control.
Dec 29, 2008 | American Standard 2748.328 Town Square 5'...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Difference between acrylic and fiberglass
Acrylic is a solid sheet material that is heated and vacuum formed to the desired shape. It is then reinforced at the back with fiberglass to give it strength. It is a higher-end material, very durable and super easy to clean. Fiberglass is a material that adheres to a mold and then a gelcoat finish is sprayed onto it. The most common material used in tubs and showers and is the most economical. Cast iron tubs are forged and the finish is applied in powder form while the tub is hot causing the finish to melt onto the cast iron. Synthetic tubs are molded and then a gelcoat finish is applied like the fiberglass tubs.
Aug 27, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Whirlpool Pearl Ballade True  Bathtub with Back Massage - 100463-100 Logo
741 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
