Question about Makita Tools 1/2" Spade Handle Drill - 6013BR
Drill Presses Safety question
What safety measures are to be considered while operating Drill Press?
    President:
  • 2,712 Answers
Before connecting a drill press to a power source be sure that the voltage supply is the same as that specified on the nameplate of the tool. A power source with a voltage greater than that specified for the tool can result in serious injury to the user, as well as damage to the tool. Using a power source with a voltage less than the nameplate rating is harmful to the motor. Also, when operating the drill press, use safety equipment including safety goggles or shield, ear protection and protective clothing including safety gloves; Keep the area free of tripping hazards; Periodically check that all nuts, bolts and other fixings are properly tightened; Never use your hands to remove dust, chips or waste close by the drill bit.
Posted on Aug 27, 2008
Westcraft. Where can I get a manual and assembly diagram?
[PDF]Operating Instructions and Parts Manual Drill Press
https://www.northerntool.com/.../manuals/12...
Northern Tool + Equipmentour Authorized Service Centers located throughout the United States can give you quick service. ... HOW TO GET SERVICE ..... Exploded View Drawing JDP-15M/MF . ... If you are not familiar with the proper and safe operation of a drill press, ...
www3.nd.edu/.../Jet%20Drill%20Press%20JDP...
University of Notre DameCompletely read the safety and maintenance instructions before operating or servicing the machine. To obtain maximum life and efficiency from your JET Drill Press, and to aid in ... Authorized Repair Stations located throughout the United States can give you quick ...... A spindle speed and pulley/belt arrangement chart.
[PDF]Operating Instructions And Parts Manual 17" Drill P
Dec 18, 2015 | Drills
McGraw-Edison drill press 2620t2 power switch won't change to on. Is there a safety on the switch that will allow it to function?
if it is a round red button, twist it and pull out
because of safety reasons much of machinery now has this type of control switch so that in an emergency the button is pressed and the machine stops and it stays locked off
Nov 15, 2015 | Drills
HOW FAR DOES THE CHUCK TRAVEL IN IT'S FULL MOVEMENT
This will all depend on your bit an your table setting. The chuck is easy to determine. Just measure the distance it travels with a tape measurer.
Jun 22, 2015 | Skil 3320-01-RT Factory-Reconditioned 10"...
I am considering buying this used drill press. How do I change speeds on this drill?
If the drill press has multiple pulleys, you move the drive belt up and down. Larger motor pulley to smaller drill pulley has higher speeds, and vice versa.
Mar 06, 2015 | Drills
Can I take my duracraft drill press chuck apart to clean it?
usually that requires special fixtures to remove the collar and a press, I would recommend cleaning with WD-40 and wiping clean all exposed parts and if you have compressed air try using that also, WEAR safety glasses.
Feb 07, 2012 | Drills
How do oscillating drill presses work? I have an old Craftsman 8 inch drill press with spindle sanding capability, but the spindle will not oscillate up and down.
Did you already read your manual for that drill press?if your manual is available there is an instruction on how the drill press work..I think the problem their is the shaft that can be found at the right of the drill press..maybe the error is that the wiring of the shaft.
Jun 11, 2011 | Craftsman Drills
I would like to know what inspections/maintenence should be performed on drill presses, say monthly and than yearly. I want my machine to stay in tip top shape.
Depending on how much the Drill Press is used will determine the maintenance required.
For light to moderate usage a monthly clean and lubrication of turning / sliding parts with a general inspection of drive belts and pulleys will be sufficient. Heavier usage will require more frequent cleaning, lubrication and inspection.
Yearly maintenance will be the same as the monthly check with possible replacement of the drive belt if showing signs of wear or deterioration such as cracking and checking bearings of drive motor for signs of wear or noisy operation. If possible, an electrical safety check should also be carried out at this time by a suitably qualified person.
Feb 16, 2011 | Craftsman 12" Drill Press (21914)
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Jig Saws safety problems
look out for the following safety features: * Safety switch or lock off button * Some saws have a soft start feature that starts the saw at a slower speed. * Blade guard that shields you during use
Aug 27, 2008 | Dewalt DC6KTJA 18v. Xrp Super 6 - Kit...
Drill Presses Installation
Here are a few instructions to follow while installing a Drill Press: Fix the column support to the base using the three screws provided. Slide the table clamp onto the column and align the table with the base and secure it in position using the table clamp lock. Place the head assembly onto the column and slide it down the column as far as possible. Align the head with the table and base and tighten the head locking grub screws with the hex key. Fit the depth scale. Attach the feed wheel. Secure the feed wheel in place with the cap screw using the hex key. Fit the chuck safety shield over the collar of the spindle nose and tighten the clamp screw. Carefully clean out the tapered hole in the chuck and the spindle taper using a clean cloth. Hinge up the shield. Push the chuck onto the spindle and lightly tap the chuck with a piece of wood to ensure proper fitting.
Aug 27, 2008 | Makita TW0350 1/2" Drive Impact Wrench
Makita Tools 1/2" Spade Handle Drill - 6013BR Logo
137 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
