Question about Makita 6825 Factory Reconditioned Drywall Screwdriver
Drill Presses problem
If my drill press needs adjustments, what should I do?
    President:
  • 2,712 Answers
If adjustments are necessary, follow the this procedure: Spindle side-play can be minimized by adjusting the locknut located on the left side of the motor unit 1-1/2 inches behind the spindle and towards the bottom of the motor unit. While moving the feed handle up and down, tighten the lock nut until the play is minimized, but not so tight so as to restrict free movement of the spindle. The spindle should return by itself to the full up position. The drive belt tension may be adjusted by removing the top cover and then loosening the two nuts on either side of the motor pulley. Adjust the motor position and tighten the nuts so that moderate finger pressure against the belt causes it to deflect 3/16" to 1/4" (see Figure 6). Excessive belt tension may result in damage to the bearings. Note: Belt tension can also affect the generation of "noise" in the drill press. Although it does not affect drilling accuracy, it may be desirable to adjust the tension for minimum noise. The spindle has been generously oiled at the factory. You may have to periodically wipe off oil that makes its way down the spindle.
Posted on Aug 27, 2008
I need a manual for the 5 speed DP MINI 1/3 hp 1/2in chuck. I really need the assembly manual. Can u help me find this
Northern Industrial Tools Benchtop Mini Drill Press - 5 ...
www.amazon.com > ... > Stationary Drill Presses
Amazon.com, Inc.Northern Industrial Tools Benchtop Mini Drill Press - 5 Speed, 1/3 HP - Power ... Yes the directions are bad as other reviews have said, but 3 bolts 3 screws and ...
Oct 15, 2015 | Drills
Lost the chuck for my master force 12" drill press where to get replacement part
[PDF]12" Drill Press - Menards
https://www.menards.com/main/store/...Tech.../240-0064.pdf
Menards12. REMOVE ADJUSTMENT TOOLS. Always make sure all adjustment tools are removed from ... Should any part of the drill press be missing, damaged, or any electrical component fail to ...... Use only MasterForce™ replacement parts. Use of ...
MasterForce 12" Drill Press Repair Questions, Solutions and ...
www.fixya.com > Forum > Drill Presses > MasterForce
Free expert DIY tips, support, troubleshooting help & repair advice for all Drill ... Lost the chuck for my master force 12" drill press where to get replacement part.
Lost the chuck for my master force 12" drill press where to ...
www.fixya.com/.../t23651560-lost_chuck_master_force_12_drill_press
Feb 24, 2014 - Lost the chuck for my master force 12" drill press where to get replacement part Where to get spare parts - MasterForce 12" Drill Press question.
Drill Press Parts & Coring Drill Parts ' Tool Parts Direct
Feb 24, 2014 | MasterForce 12" Drill Press
I want to put a taping head on my drill press. What is the spindle size of a craftsman 12" drill press?
without the model number I am going to guess that as a general rule most smaller drill presses are a #2 morse taper socket and a #2 jacobs taper arbor (where the chuck presses on) you should have been supplied a knockout pin to remove the chuck assembly from the internal socket.
Apr 15, 2011 | Craftsman 12" Drill Press (21914)
My pinion arm works and lowers my drill bit but it will not go back up, it just stays down. Is there some sort of spring or adjustment that needs fixing so it will automatically go back up?
Most presses have a knob on the left with a spring in it just for this purpose. Mine is ancient and all I do is spin it and it tightens up. Check it out.
Jun 13, 2010 | Delta 15IN Stroke Production Drill Press /...
My headlights need to be adjust on my renault lagua ( 1998 )
There will be adjustment screws on the headlight units accessible from inside the bonnet(hood).
Mar 27, 2010 | Laguna Tools Platinum Series 17" Variable...
How do you ajust the high and low speed on the drill press
not sure if you have a dial on that press to adjust the speed. if it is a dial on the machine make sure you adjust it while it is running.... but it looks like it is belt driven and there will be a series of pullies under the top cover for adjusting the speed.
Mar 03, 2010 | Delta Machinery Delta ShopMaster DP350 12"...
Press stops under even slight pressure on drill
adjust tension on pully or the belt may be worn or streched replace belt.
Nov 15, 2008 | Drills
Drill Presses Models
When shopping for a drill press, you'll have to choose between two basic models: 1. Bench-top drill presses mount directly to a workbench or on their own stands. Their compact size makes bench-top models good choices for small shops. 2. Floor-model drill presses usually have more powerful motors, more attachments/accessories and greater material handling capacities than bench-tops. The extra versatility makes floor models good choices for serious DIY and commercial shops.
Aug 27, 2008 | Dewalt Delta DP300L 12" Twinlaser...
Drill Presses Features
You compare the following features: Horsepower (HP) is the maximum power produced by the motor. Higher horsepower allows you to bore larger holes through tougher material. Drill presses are available with motors from 1/4 to 1 HP. Size/center drilling capacity is determined by the distance from the center of the chuck to the column. Since the press can bore a hole in a circle with a diameter two times the distance from the center of the chuck to the column, the size is listed as twice the distance from the column to the center of the chuck. A 16" drill press can drill a hole up to 8" from the edge of a straight board or at the center of a 16" diameter circle. Variable speeds allow you to drill different diameter holes through different materials without damaging the material or drill bits. Drill presses are available with five to twelve speed settings. The more speed settings, the more versatile the drill press. The table on most drill presses can be raised and lowered along the entire length of the column. It can also swivel 360° around the column for boring oddly shaped pieces. Better presses have large, tilting tables with fences. Quill travel determines the depth to which the press can bore holes. Greater quill travel allows you to bore deeper holes. Depth-stops control the depth to which the quill descends and limit the depth of the hole. Depth-stops are good for repetitive boring and dowel holes. The more precise your depth-stops, the more accurate your boring operations.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Makita 6825 Factory Reconditioned Drywall Screwdriver Logo
325 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
