Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
How do I use the memory stick?
How Do I Record And View Still images With The Memory Stick?
    Master:
  • 473 Answers
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Posted on Sep 06, 2005
SOURCE:
How do I record from Sony TV 55S8505CBU using a memory stick
Hi Howard
As far as I know you can only use your memory stick to view items such as videos, pictures, and music. If you want to record you will need to invest in a hard drive.
May 29, 2016 | Sony Video Cameras
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
How to delete pictures?
To delete the images from the Camera, press the Play button on the Camera to view the images. Display the images which you want to delete and press the DELETE button (Recycle Bin icon) located below the lower left of the Control buttons.
To delete multiple images, slide the index lever and select with the control buttons.
While the index screen is displayed, press the Delete button and select the images with the control buttons and select Enter button. Now, select the images which you want to delete and press the Enter button to display the Delete icon on the images. Press the Delete button again to delete all the images.
You can also delete all the images in the folder by selecting All in this Folder to delete the images.
To delete all the images in the Memory Stick you can select the Format option from the Internal Memory Tool or the Memory Stick Tool Menu to Format the Internal Memory or the Memory Stick.
Thanks for using FixYa.
Jan 27, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
How do i view the pictures on a psp. Ihave saved
first you have to format the memory stick in psp using the option format inside the psp and then put it in pc and then put the pics in the picture folder in the memory stick
Mar 04, 2009 | Sony PSP (Piano Black)
Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Nov 13, 2008 | Sony Handycam HDR-CX12 Flash Media...
Cant View Thumbnails on Camera
you can delete images from the 'stick' on computer- so long as you do not format on computer.
Mar 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
159 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
