Question about Grohe 40.344.000 Essentials Bathroom Accessories Kit - Chrome
How to Install Towel Bar?
How do I install a towel bar in my bathroom?
    President:
  • 2,712 Answers
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Posted on Aug 27, 2008
My towel bar won't stay tight
maybe you need new screws in the bar?
Nov 30, 2012 | Delta & Soap Dispenser
How do I install a moen mason towel bar?
Do the tips come off? Is it possible that the bar slides through the brackets? Most high end hardware has very small Allen screws to mount it. If not, go to Moen website for instructions or a phone number
Mar 24, 2012 | Moen 24 In. Towel Bar...
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
I need to remove a Moen towel bar. It has a tab under the bottom but I dont know what to do
There should be a "set-screw" (a very small screw) at the bottom of base (fat part) of the towel bar. It screws in to hold the fat part of the bar to the "tab". Loosen the screw by turning it counter-clock-wise. Once loose, the towel bar will lift off the tab. Be careful not to lose the screw!
Feb 21, 2011 | Moen YB8086 Mason Towel Ring Bathroom...
The plastic end piece which fits into the Milano towel bar has broken so that the towel bar doesn't stay in place. I don't know where to find a replacement.
"Milano" or "Geneva"???
Geneva 24" Towel Bar:
http://www.grohecatalog.com/product/40146
Contact Grohe. They might just replace the broken part.
http://www.groheamerica.com/en/contact-grohe/p/25_16615.html
From their web site:
"For Warranty or Replacement Part information
Please be sure to provide your product / part number, type of product finish, the original install / purchase date of the item in question and leave your shipping address (cannot be a P.O. Box), daytime phone and (if available) a fax number, in order for us to contact you if necessary or promptly send your requested information and/or part(s)."
To fill out an online request form:
http://www.groheamerica.com/en/contact-grohe/customer-service-email/m/25_16617/page/modules/formchain/
Feb 08, 2011 | Grohe Geneva Chrome 24" Bathroom Accessory...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
How can I attach a ceramic towel bar inside a tub surround without drilling through the surround? I was thinking about a good water proof glue. Any suggestions??
You could use a good water proof glue but that would only work for a short while. What kind of material is the surrounding made of? Ceramic towel bars are normally set in ceramic surroundings. If you really must have this towel bar you may have to cut two squares out of the surrounding and put in two ceramic tiles, that way you can put ceramic on ceramic.
Oct 04, 2010 | Moen 24 In. Towel Bar...
How do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
Jul 17, 2009 | Moen 24 In. Towel Bar...
Grohe 40.344.000 Essentials Bathroom Accessories Kit - Chrome Logo
800 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
