Question about Dynasty Hardware Pacific Shower Basket or Shelve 3761-CM
Heating Water Speed
How fast does a Instant Water Shower Heater heats water?
    President:
  • 2,712 Answers
Approximately 10 seconds instantaneous heat.
Posted on Aug 27, 2008
I have a Westinghouse WGRTNG199 tankless water heater. It will stop heating water and show code 42 on the screen when someone uses one specific shower in my house. This is the closest bathroom to the...
There is an outstanding chance that the shower causing the problem has a required flow restrictor installed in it. If you take the shower head off and look in the connection are you should see a colored screen or similar plastic piece. Take it out. The water heater has to have a flow of at least 1/2 gallon per minute.
Dec 22, 2017 | Water Water Heaters
Getting popping noise from water heater after shower
Popping sound is caused by sediment built up in bottom of tank: air bubbles get trapped when heating starts, and then they crackle, rumble etc when free.
Clean out sediment:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/pdf/How-to-descale-water-heater.pdf
The steps vary by type of water heater, gas or electric
Jun 27, 2013 | Water Heaters
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have powerstar model # 45557701- what causes the cracking noises when water is heating? what will make the unit slow to start to heat? how can i change the heating units?
The crackling noises is just from air in the water and should be of no concern. If you are having a problem of heating up the water with the unit it is most likely do to water moving too fast through the lines. Ideally, there should be a shutoff valve installed on both sides of your heater (makes for easy removal if it needs to be serviced). But if you turn off the valve about 1/4 to 1/2 way on the one on the "in" side of the heater (where the cold water enters) then you will slow down the water going through the heater and this will give the water a better chance to heat up. This should alleviate the heating problems you are having. If you do have a shutoff valve on the cold (in) side of the heater, shut it off about 1/4 to 1/2 way and then go to your shower and turn the hot on all the way (no cold). Wait for the water to warm and test the water by hand to see if it is the temp you want. If it is still not warm enough, turn the hot on the shower DOWN just a little. This will actually make the water hotter. I know this doesnt seem right but it will. On the other hand, if the water coming out with the hot water fully turned on is too hot, then just turn on a little cold water at a time until the water is the temp you want. Remember, always give the water plenty of time to get from the heater to the shower before you decideof its the right temp. Ideally, you should be able to turn the hot water on all the way and get the hot temp that you want and if you want to cool it down, just turn the cold on just a little bit until it is where you want. I'm fairly sure the problems you are having are due to the water going too fast through the unit and once you adjust that and understand better how these tankless heaters work, you wont have any more trouble. They are difficult to get used to after using conventional water heaters and the manufacturers arent very good about giving you these hints so they will work properly. You will need a professional to uninstall and hopefully this will work and you want have to. But if you do, it requires shutting off the water to the unit. Shutting off the pwer to the unit. Unattaching the water lines to the unit and then unattaching the electric lines from the junction box or wherever they are attached. The heater then can be removed from the wall by unscrewing the screws from the hangers which hold it to the wall.
Feb 21, 2011 | Bosch PowerStar AE115 Tankless Water...
Squealing noise inside the tank
Does the water come out really hot while it is squealing? This is sounding like the water flow is not fast enough and is heating to almost a boiling point. I have experienced this myself with gas heaters. If you open the hot water valve more in your bath or shower does the sound go away?
Jan 29, 2011 | Rheem Direct Vent Natural Gas Tankless...
I recenty purchased and installed a Whirlpool electric water heater model #E2F40RD045V, when the lady of the house wants to take a shower the hot water doesnt stay hot the whole time. The water heater is a...
Sounds like one of your heating elements is not heating properly.
Check to make sure you are getting power to both of the heating coils, you can check that by removing the two covers over the heating elements and checking with an electric ohm/volt meter for power to the elements. If you have power going to both elements then you will need to check the elements themselves.
Unplug the water heater and then check the two heating coils to make sure they have continuity across the two terminals. You probably will find only one is working, replace it with a new element and enjoy all the hot water you can use.
This is a FREE answer, Please rate me
Dec 05, 2010 | Home
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Dynasty Hardware Pacific Shower Basket or Shelve 3761-CM Logo
63 people viewed this question
Top Dynasty Hardware Home Experts
john h
Tom Chichester
Are you a Dynasty Hardware Home Expert? Answer questions, earn points and help others
